The 2.2L s2000 motor doesn't have the highest bhp/displacement. Exotics (and even some high end sports cars, like the elise or TVRs) have far more than the 109bhp/L that the s2000 motor has.240sHorTy wrote:I don't hate on the Honda's personally. I drive a CRX HF as a daily and I love the 45ish MPG it gives me. I also looked at a custom Miata in Cinci that had the s2000 drivetrain. Would've been a bad little car to own. You may have seen the article in Super Street on it. That engines has, or at least had the highest power/displacement ratio of any production engine. I pesonally respect the VTec power plants. And I would've bought a Prelude if it were RWD. Honda's biggest flaw is not offering an economical rear drive car similar to a 240.
And the B16 was considered the mild B-series.frapjap wrote:and had the B16 swap into it.
Firstly, the F20C (2.0L, 240hp), by definition, had a better hp/liter ratio than the 2.2 did, so why compare the 2.2? It produces 120hp/liter, which is VERY impressive indeed for a production car. So thus, as comparison:InsanityInc wrote:The 2.2L s2000 motor doesn't have the highest bhp/displacement. Exotics (and even some high end sports cars, like the elise or TVRs) have far more than the 109bhp/L that the s2000 motor has.
rx8 180 hp/ltr.HashiriyaS14 wrote:Firstly, the F20C (2.0L, 240hp), by definition, had a better hp/liter ratio than the 2.2 did, so why compare the 2.2? It produces 120hp/liter, which is VERY impressive indeed for a production car. So thus, as comparison:
Ferrari 360: 111hp/liter (3.6L, ~400hp)Ferrari 430: 113hp/liter (4.3L, 490hp)Ferrari F50: 109hp/liter (5.7L, 513hp)Ferrari Enzo: 110hp/liter (6.0L, 660hp)Lotus Elise (Toyota 2ZZ-GE): 103hp/liter (1.8L, 187hp)
If you can find a production car that does 120hp/liter, go for it, but there can't be too many of them. I can't think of one. Stop being wrong all the time, I'm getting tired of correcting you
Yeah, I knew the Rotaries were all way higher, but that's sort of a different benchmark. What car does the SR16ven N1 come in? That's a helluva ratio? So it's a naturally aspirated production-car 1.6L engine that produces 196hp?Chingon wrote:rx8 180 hp/ltr.
Unless we are talking reciprocating, then it still fails against nissan's own sr16ve n1 123 hp/ltr.
Pulsar VZ-R N1, Pulsar VZ-R SSS N1HashiriyaS14 wrote:Yeah, I knew the Rotaries were all way higher, but that's sort of a different benchmark. What car does the SR16ven N1 come in? That's a helluva ratio? So it's a naturally aspirated production-car 1.6L engine that produces 196hp?
NOTE: If anyone else finds engines that best 120hp/liter, cool, but it wasn't my intention to say that they didn't exist. I just wanted Insanity to be aware that the Elise and all those Ferraris didn't have the ratios he might have thought they did.
TVR Speed 12. 7.7L, made over 1000WHP (they don't have an exact number because it broke a 1000WHP dyno). With the restrictor plate in place, it still made 840ish BHP.TVR Speed 8. 4.1-4.5L, made about 550HP if I recall, varied depending on the car it was in.HashiriyaS14 wrote:Firstly, the F20C (2.0L, 240hp), by definition, had a better hp/liter ratio than the 2.2 did, so why compare the 2.2? It produces 120hp/liter, which is VERY impressive indeed for a production car. So thus, as comparison:
Modified by HashiriyaS14 at 11:16 PM 8/21/2005
tvr cerbera speed 12 never saw production and the tvr speed 12 was only built for racing.InsanityInc wrote:TVR Speed 12. 7.7L, made over 1000WHP (they don't have an exact number because it broke a 1000WHP dyno). With the restrictor plate in place, it still made 840ish BHP.TVR Speed 8. 4.1-4.5L, made about 550HP if I recall, varied depending on the car it was in.
They don't make either one anymore, though.
And what are you getting tired of correcting me about? The last thing I recall you "correcting" me on ended up with you being unequivocably wrong when I quite clearly demonstrated that the supra was in fact rice, by ANY definition.
ILikeMy240sx wrote:Civic "walks" a z06 puhahahahahahahahaaaaa
Last time a Civic tried to race me I beat him with a KA and a bad knock sensor with check engine light... psh.
There were a few produced, but I'm not sure if they ever sold them. The engine was most definitely produced in a form that could run on normal gas, though. And there are higher output versions of the speed 8, those are probably specs for an earlier model (like the one used in the old griffith 500s).Chingon wrote:tvr cerbera speed 12 never saw production and the tvr speed 12 was only built for racing.
tvr cerbera speed 8 4.5 - 420 bhptvr cerbera speed 8 4.185 - 360 bhp
But I did think of another one:Tiger racing z100wr something like 165 hp/ltr, but they use bike engines..
i found: first GM experimented with vvt & vl but abandoned it due to some technical problems. then fiat developed the first functional variable valve timing & variable lift in the 70's.InsanityInc wrote:VTEC isn't copied by everyone. Despite popular belief, VTEC is very ****ing far from the first example of variable valve timing. Ferrari was the first to use it if I recall, and toyota had it before honda.
I drove a stock 91 Civic DX Sedan for years. I know it's a world of difference from what you guys talk about, but I found that with a Honda you accelerate with the stick, not the throttle, so to speak. What I mean is that if you want to accelerate at all on a highway, you downshift.JimmyMethod wrote:Second, with a manual, you can keep a bored out low-torque engine up in the range where it stays on the power cam, giving you plenty of acceleration.
