InsanityInc wrote:That's with the restrictor plate on, as they originally used the engine for racing which required one. When they took it off and tuned the engine for production, they had no idea how much power it made because it literally broke a 1000whp dyno. It broke the machine. Then they ran the car like that and it did 0-60 in under 3 seconds.
http://www.iol.ie/~donohoer/0TVR_Speed_ ... su....html
If you want more sources, just google it and look around. It's pretty commonly known.
The speed 8 has been in use for a while, but the more highly tuned recent versions of it before they stopped production made over 500BHP.
Ok, we're getting off the subject, so I'll make the following points:
A.) I never said there was NO production car that had a better hp/displacement ratio than the S2k did, so I don't see how it's worth your while to continue to mount an increasingly-complex argument about how a non-production model TVR engine bested 120hp/liter. It's not relevant.
B.) You used the ratio from the 2.2L S2000 engine, which doesn't make any sense. Either you were unaware there was a 2.0L with the same power output, or you were just intentionally trying to slant the argument. Neither of these options looks too good....
C.) You said that the Elise has a better ratio, and you were incorrect. You also asserted that lots of exotics had a better ratio, which is also not the case, or at least you have yet to prove that it's the case.
InsanityInc wrote:And I'm pretty sure when you stopped responding and everyone ended up agreeing with me except for one person that made you wrong.
Really? Is that so? Well, it so happens that I just pulled that thread up in a search, and so here's a link so everyone can go re-read it. I encourage everyone to go browse through it one more time, just for kicks:
zer...age=1
I didn't see many people agreeing with you, but I did see the following, after my departure:
-Veriest repeatedly tearing you a new one every 3-4 posts
-People accusing you of ruining other threads on our fine forums, and even of repeatedly dogging a moderator.
-Numerous well-respected and long-standing NICO members disagreeing with you, often forcefully, including moderators.
-Looks to me that you had a couple of recurring supporters there, and by "a couple" I do mean two.
I'm not terribly big on vendettas, you see. I already have more than enough real-life arch-nemesi that I needn't waste my time with the online variety. Thus, I'd appreciate it if you didn't continue picking fights all the time. I'll bury the hatchet if you agree to calm the hell down.
