slidestyle69 »
https://forums.nicoclub.com/slidestyle69-u130087.html
Wed Aug 19, 2009 8:49 am
no no no, what has happened is you just bought your motor from an importer, well importers are quite dirty when it comes to assuring you, you have a sound motor..
the reason is, they pour oil in the cylinder to raise the compresion of the motor so when you check it it's good.
dont worry about this at the moment, get it running and then run for a few to burn up the oil and then test again.
by the way cory, the pulsating voltage to the injectors is 12v.
