There were somewhere around 130,000 miles and 100+ passes on the motor. It wasn't the best maintained either, but it ran.LEMHEAD16 wrote:Wow that really sucks. Whats with all the VHs spinning bearings. It seems like everybody gets their project finished and then spins one.
How many miles were on the motor?
Awesome numbers though!
You have a good memory. I don't think the motor was to blame, I think the 8000RPM was to blame. Yes, I rev'd it that high, and it made power that high as well. It was still making 240WHP+ at that RPM.90TSIAWD wrote:Tough break especially after seeing such great gains initially. I hope things get put back together eventually. Good luck with that once you decide to get back into it.
LEMHEAD16, if I remember correctly on either the page or one of the videos it said roughly 131,000 I think.
I'm seen tuned stock VH's make 300WHP through a Z32 5-speed. I'd expect 340WHP cam'd.DJ Raijin wrote:so tuned and not running a TH400 we can expect to see about 300whp? That's awesome.
Sucks about the spun bearing though. It's always nice to take a break. It helps you refocus yourself though and get motivation back.
I don't know how to respond to this. Were you expecting 100WHP? A 40WHP gain NA from a cam change only is significant in anyones book. I'd easily expect another 10HP after a tune. 50WHP total is a 20% increase in output.elwesso wrote:Do you think that the cams are worth the effort? i mean 40HP is significant, but all things considered???
Im thinking that boost is the way to go.
Like I said above, I don't think the VH was to blame. The mileage, poor previous maintenance, and 8000RPM are what caused it.tmorgan4 wrote:That really sucks to hear.
It seems like it's about time to figure out why these VHs all seem to be spinning bearings. I haven't heard of a single stock Q45 that spun a bearing although I'm sure it has happened many times. Do any of the VG, SR, or RB engines have these problems?
I'm figuring the increased compression is worth another 20HP, but only time will tell. I don't think this motor will be done before next winter. I don't have boatloads of cash to throw at this car, right now I'm just dealing with the fact that I won't get to race this season.Orphan wrote:Sounds great. I can't wait to see the results. If you can get near 340whp out of a standard VH45 with cams and a tune that is quite impressive with with that 12.5:1 compression you should be looking at some nice numbers.
Forgive my lack of knowledge but what would be a safe compression level for the road? I haven't really seen any production car over 11.3:1? Over here you can get 98 ron from literally about 98% of petrol stations and a few shell stations offer 100 ron.
EDIT: I just found out the newish BMW M3 4L v8 has a CP of 12.0:1 so I'm guessing using 12.0:1 would be fine on a street engine if tuned right?
It seems prepped VH45 rods are fine for 400-450hp so with the ARP bolts what revs do you think would be fine on them? Because while they aren't the most robust rod they are pretty decent looking even compared to some aftermarket rods besides they aren't billet.
It was still the original chain, retensioned to factory tolerances. FWIW I have an oil pressure gauge and warning light, the motor never lost pressure. The crank pulley was also tensioned to factory specs.Carl H wrote:a 40-50hp gain from cams is nothing to sneeze at and is actually quite impressive.im curious tho as to if you changed the oil pump drive chain when you had it apart...i find it odd that there have been several vh engines with spun bearings that have seen relatively 'little' extreme duty.
Probably because of my camera's sound quality.Orphan wrote:Why does the engine sound a bit like a helicopter (first cam'ed vid). What was it idleing at with the cams?
Can't wait until mettler finishes his research and see how the cam support comes up for these engines, using the VTC should be able to run some decent cams while retaining drivability.
I talked to Mark this morning. I'm not sure which way I'm going to go yet on the intake, but the bottom end will definitely be built. Looser bearing tolerances, CP Pistons, ARP Rod bolts, etc...gs14racer wrote:Steve,
With a short runner manifold or individual throttle bodies do you think you will see a bigger gain up top then just flat lining after 5500 rpms.
I would think with itbs, 12 to 1, and the cams 370+whp would be possible with a 9000rpm redline. I think at this point the intake manifold is holding you back. I mean figure 340 whp +15-20 for the higher compression, and your right there with the intake manifold change. Not to mention if you could up the displacement a bit say 4.8-5.0 liters which is definitly possible per mark.
The motor makes such a broad and flat torque curve that it never really feels "alive" even though it's really alive everywhere.CrazyTrance wrote:It does seem quite dead at around 4-5000 rpm doesnt it. At least thats what mine feels like. Cams seem like it would liven it up. And a 40hp gain is actually very good! I was hoping for gains around there.
This is pretty much John's setup. Dont remember what cams he's using though. I think it'll make close to 400whp.gs14racer wrote:Steve,
I imagine like anything, cams alone won't net the desired gains without a few other changes... but I'm wondering whether 100HP/L will be achievable on the stock intake manifold... that's really all I'd be aiming for myself!elwesso wrote:Do you think that the cams are worth the effort? i mean 40HP is significant, but all things considered???
Ok, I *think* I understand what you're saying now. What is the cam timing at idle then? And after the shutoff (or are they going to be the same).Q45tech wrote:The purpose of VVT is two fold to allow a semi radical 248 cam [for a heavy lux car] to idle perfectly smooth before the oil pressure increase above idle pushes cam to 20 degrees BTDC where it stays until the oil pressure is cutoff by closing the VVT solenoid at 4500-4800 rpm. The VVT allows a 8-10% peak in torque from 3500-4500 rpm. That's 25>30 lb/ft.
VVT use only gets better with a more radical cam especially at idle.
