PanzerAce »
https://forums.nicoclub.com/panzerace-u127165.html
Thu Apr 16, 2009 8:14 pm
I should have made myself more clear on the failure point. I'm not saying that they will fail faster than normal, just that when they *do* fail (and all engines will at some point), it adds stuff to have to inspect/fix. Also, the more mechanical parts anything has, the more points of failure there are. That is why Glock pistols are so highly thought of: Gaston Glock cut down to as few parts as possible to make them more reliable.
I'll grant for sure that VVL systems make 100hp/L engines more streetable, since unlike a straight cammed engine, it doesn't have to have huge lift, huge duration all the time.
The VR was a bad example and I'll admit it, I completely forgot that one of the largest functions of VVL tech is to eliminate pumping loss wherever possible.
As for coming up with a reliable system for 100whp/L, I don't foresee any system achieving what a OEM would consider satisfactory reliability on a performance oriented application any time soon. When you consider that BMW has had the tech on the market for 8 years, and probably in the works for twice as long, it leads me to believe that there are some inherent problems with it that are taking awhile to work out (assuming they can be worked out). Obviously, VVL tech is fine for DD and commuter engines, but factory performance? History indicates it won't happen (for awhile, atleast).
Yes, the 4.2FSI, Ferrari engine, and BMW M engines have ALOT of work done to them already, but I think if you added up the cost of buying one of those engines as a turnkey setup vs. buying a VK50VE (or VK45VE in the future as a closer competitor) and building it to the same power level with factory reliability, I think you would find that the difference is in favor of the non VE stuff. I think if you built a NON VE VK engine to 100whp/L with factory reliability, it would probably be about the same price as the 4.2FSI or M engine (Ferrari is in a WHOLE different league though) (I have no actual numbers for this though).
For cheaper power without VVL, I should clarify that that counts buying say a fresh engine block/crank/heads from the OEM. If you already have the engines, then it is quite possible that VVL makes performance cheaper. (my knowledge of SR##VE stuff is non existent, so I can't really comment on any of that).
Honda Vtec I actually like a little more than the current VVL stuff, just because it relies on a second, more agressive cam load rather than levers and the like. As such, not really an apples to apples comparison for it's failure rate. I would expect the same general failure rate from Vtec and normal cam systems.
As for VTC, the more I read up on it, the more I think that it's a good system to have, especially on daily driver cars. It seems to allow for much better idles for a given power, even if you swapped manis for an ITB setup or something similar (though I'd be more than willing to try that some day if I had the money). There is ALOT of potential is the stock VK and VH DE engines, and I'm surprised that there aren't more 100whp/L NA engines out there. Though, as you point out, it's probably because turbos are so easy/common these days.
As for the L series, I don't remember the guy who's running it. I'll try to find it on HybridZ again (it's a good read in general). It is a pretty big mod list, but it isn't something that is out of the realm of a normal garage mechanic. The stock L28s and L28ets are so handicapped that it isn't even funny. The intakes flow terribly, the stock exhaust is a crime against humanity, and the cams are anemic. The 330whp guy is running triple 45mm Weber carbs (a pretty common swap), a much freer flowing exhaust, and a pretty wild cam.
As a price analysis, Rebello Racing (the go to guys for L series stuff), could probably build a 100whp/L L engine for maybe 5k tops.
Speaking of price, that is the real hampering point of VK/VH stuff right now: The lack of aftermarket support. If it had even the level of support that the L series has, much less the KA/SR/LS/SBC engine platforms have, a 100whp/L NA build could probably be done for maybe 4k on top of the price of the engine.
I would love it if you could get some pics of the VE system, since to be honest, the pictures/diagrams I can find with quick google searches aren't very good.
