Lynchr »
https://forums.nicoclub.com/lynchr-u169490.html
Sun Jul 22, 2012 1:00 pm
I bought my 06 M35X from an 88 year old gentleman 3 years ago. The transmission shifts promptly on both up and down shifts. There is no hesitation at all and it is very responsive.
He provided all service records from new. While reviewing them I saw were the dealer had preformed the trans service, and then 6 weeks later an Independent shop "sold" him a transmission service again. On the independent's repair order it just stated xx quarts of transmission fluid.
I took the car to my Infiniti dealer to have the fluid changed again and emphasized that I expected that Nissan Matic J fluid be used. I was assured it would be.
While paying my bill I glanced at the RO and saw xx quarts of bulk transmission charged out. I confronted the service manager about not using Nissan fluid and his reply was "we know what we are doing".
I told him I was from Nissan Corporate, Service Operations, and he didn't know what he was talking about, and he should check the service manual for fluid requirements. He agreed to replace the fluid again with Matic J. Interestingly, not long after this, the dealership had a new owner.
The reason I'm explaining all this is so that DIY'ers understand how important the fluid is. The following is taken from the M service manual (I think it is also stated in the owner's manual):
"CAUTION:
Use only genuine NISSAN Matic J ATF. Do not mix with other ATF.
Using ATF other than genuine NISSAN Matic J ATF will cause deterioration in drivability and automatic transmission durability, and may damage the automatic transmission, which is not covered by the warranty."
If I recall correctly, Matic J has been replaced with Matic S.
Not knowing the OP's car history this could be a factor. All the symptoms mentioned sound like the clutches are slipping. Also, if water ever got in the trans (such as in a flood, or driving through high water) it will also take out the clutches if not immediately flushed out.
Sorry for the novel.
