SlidnSideways »
https://forums.nicoclub.com/slidnsideways-u27106.html
Tue Aug 30, 2005 3:03 pm
NISTECH, The car is running awesome! After replacing the air filter, finding a vacuum leak, and adjusting the timing, the car came alive again!
I still think i MAY have an exhaust leak though. When i rev the engine i get a rattling similar to the rattle of a heat shield. Since i replaced the cat do you think the top heat shield could be doing this? Im not thinking its that because the cat is brand new.
I also have another rattle type noise that sorta sounds like its comming from the inside, upper part of the engine. I did the timing chain replacement myself and i know its not the guide rattle but i think i remember the guy at the machine shop telling me that the new rockers and stuff he installed may be a bit louder. My neighbor also tells me it may be because of my new hotshot header i dont have the insulation as the old bulky cast iron header to block the noise and its normal. Does that sound right? Im going to go change my oil as soon as my car cools down but i also remember finding a rubber, gasket-like sealer looking thingy under my car when i replaced the head and after thinking about it im thinking it was the rubber liner around the oil filter (perhaps from over-tightening?) Anyway could this be causing the second rattle noise?
Im sorry im bugging you so much about this P.O.S i wish it would just work for me cause i hate hating my 240 lol.
(EDIT: I changed my oil and checked over possibilities.... Guess whats missing 2 bolts again! ...im tired of this....
--Tim--
Modified by SlidnSideways at 10:33 PM 8/30/2005
