slow take off until you almost have petal to the metal
infinit-t
Car: 1993 j30t
Can some 1 give directions or diagram on how 2 reach the Knock Sensor......This thread is kinda popular ya think it should b a sticky??
GerryO
Car: 1993 J30t
Pearl White
Black Interior
I found this on another forum.
"My advice is to relocate to the rear drivers side bolt that holds the upper plenum to the lower plenum.
Required: M8-1.25 x 100mm bolt, M8 lock washer, M10-1.50 nut, and M8 flat washer.
This is what some people do and it is fine. Others can argue this but unless you are taking apart the motor then this is a more than ample solution to get you going again."
But do you have a ECU Code 34? It's worth checking for and patching in the resistor would really confirm things.
gr8scott72
Car: 1994 Infiniti J30t
infinit-t wrote:Can some 1 give directions or diagram on how 2 reach the Knock Sensor......This thread is kinda popular ya think it should b a sticky??
You don't "reach" the KS without MANY hours of work taking the upper AND lower intake manifolds off. Of course, you then have to put them back on.
Just get a new one and a new wiring harness, relocate it and be done.
