Assuming that it's an American car and probably just RWD, is it possible that the front dyno rollers are motorized for some reason? Anyone with dyno experience can chime in here...EXceptional wrote:Interesting build.
Did anyone notice in the Video how the Rear Wheels turned before the Fronts did?
What's with that?
Shouldn't all four start at the same time?
That is how the "Intelligent All-Wheel Drive" work...kamiguy wrote:Assuming that it's an American car and probably just RWD, is it possible that the front dyno rollers are motorized for some reason? Anyone with dyno experience can chime in here...EXceptional wrote:Interesting build.
What's with that?
I assume its hyperbole when you state that a Corolla handles better than the EX? I've driven 1990, 1996, 2001, 2003, and 2008 Corollas (Right hand drive, left hand drive, everything from 1.3L to 1.8L) and I would characterize their handling as soft and wallowly. There's quite a significant amount of lean in a turn not to mention the fact that the tires start to squeal if you try to take a corner too fast. I came from a 3-series and I think the EX corners about as well.EibachMBZ wrote: I personally think EX with 800+hp is completely waste of money
The car handles good for a crossover but worse than a stock Corolla when comes to turn
With that type of power, the car can only go straight... I would rather use that money and built myself an American muscle car
When I dyno my RWD EX, the front roller is not engaged at all...
There is no way a corolla handles better than the EX35. The EX35 loves to slide a bit for turns and I would say, you have to know the car well to understand it`s dynamics.minimo3 wrote:EibachMBZ wrote: I personally think EX with 800+hp is completely waste of money
I would say if you slowly gas it from stop to 20mph, it probably is still on RWD . But if you floored it from stop to 20mph, I`m sure it`s AWD!ramprun wrote:i understand that the AWD kicks in when it detects rearwheels slippage but isn't it suppose to activate all four wheel from stop to about 20mph?
quote]
I read it too. This subject appeared after my project was started (February 2011). I suspect that GTM hurried to announce a TTkit on EX35, expecting to finish mine and to sell the similar. They were engaged with mine 2 years. As they claim, it was development of a kit from scratch because anything from they had didn't approach by the sizes was required.AWGD8 wrote: I read some horror story
