SLEEPY EYE GONE BAD NUMBER 2
jismo
Car: flat red 93 240sx
tell me about it, i tried the sleepy Is thing and now my retractor switch will let the headlights go up, but press the switch to go down they want move down. i mean even when you turn the combo switch they want go up, u see the lights come on underthere but still no pop up.I F**k up dude
(Q)240
Car: 92 240sx s13 Coupe
dude same here... same exact thing is happening to mines....execpt that i didnt even try the sleepy eyes mod... it just happened...what could it be?? not a relay?? let me know if u find out how to fix it.. GoodLuck!
I was told it was the light switch next to the steering wheel... try replacing it and let me know how it goes...
Duce40sx
All you guys needed to do was CUt the Brown Wire from the "Headlight Retrator" swtich.
You cannot have sleepy eyes with the Light on.
It is only for the day time.
You turn on your headlight and tap the Retractor switch " 1 , 2" quickly~
SO:
headlights on,1. Tap once (it retracts) and then tap quickly again, and it will stop. \
keep tapping 1,2, 1, 2 etc, until the sleepy eye is where you want it.
(Q)240
anyone know how to fix this PROBLEM???
Im goin crazy having my headlights stuck up????
sancosys
Thats how all the cool people roll, with the headlights up. JK but not really but that does suck BUMP to help this member out by a smarter member!
CrypticScorpio
Car: 1992 240sx SE Hatch
similer problem. headlights go up and down with the higbeams on. lows dont work at all. and the retracter button dosent work at all!
adrianfromthecastle
Car: 1992 Nissan 240sx
(Q)240 wrote:anyone know how to fix this PROBLEM???
I bet its your headlight switch (same switch as the turn signals, left of the steering wheel). If you have a friend that has an s13 too, swap switches to see if thats the problem. I'm pretty sure that it is tho...
club240sucks
Car: 93 touring FD
have u guys ever tried the brown wire sleepy eye?
guitarman13
Car: nissan sentra
howdo you do the brown wire leepy eye? i just bought a 240 and i want to do that to it, how should i go about it?
(Q)240
adrians_s13 wrote:I bet its your headlight switch (same switch as the turn signals, left of the steering wheel). If you have a friend that has an s13 too, swap switches to see if thats the problem. I'm pretty sure that it is tho...
where is this switch??? i already tried replacing the light retractor switch and was not it... can u post a pik of what it looks like??
CrypticScorpio
the combonation switch.... attached to your steering colum.... the blinker control. thats wht he means.
nateb
Car: s13 hatch *working progress*
guitarman13 wrote:howdo you do the brown wire leepy eye? i just bought a 240 and i want to do that to it, how should i go about it?
DAYTIME SLEEPY EYES
MATERIALS NEEDED:-scissor-1 functional hand
STEPS:1. take ur functional hand and pop out the the retractor switch ( located top left above cruise control/ blank switch)
2. take the scissor and snip the "brown wire" behind the switch
3. pop the switch back in
***Now just follow DUCE40SX's instructions ^^^^^^ on how to use***
i know all that was unnecessary but i was bored
drmerdp
Hmm I was the guy with the original sleepy eye gone bad. I just blew a fusable link with my mis hap, its fixed now and the lit sleepy eyes mod works like a charm.
Sorry to hear yours is a much bigger deal, i'd speculate that its the blinker/ headlight switch too. I've dealt with a few shorted ones on other cars and it was always my last part to blame. But usually the problem.
imavert
Car: nissan 240sx convertible
Ya had the same thing happen. All i hdid was buy the the turn signal and headlight sswitch and it was fixed. I think there like 60 to 70 bucks.
(Q)240
what does teh switch look like... and where can i find it... piks of switch plzzz
stealth_s13
Car: 1991 toyota pre runner
wow...sleepy eye(lazy eye) how to...easy as pie...literally took 5 mins,now if i can find someone that can give me the 5minute fix to get my brakelights to work when i press the pedal i will be as happy as the guy who got a stripper-gram that has a "happy ending"...as far as the dude looking for the pop up switch...if you cant find it...you need your car keys taken away...left side of steering colum...you will see a a switch that pushes in and out...thats the switch to make the pop ups go up and down...the combination switch it that stick coming out the left side of the steering colum that turns the lights on and operates the turn signals
tweetersbro2002
Car: 1997 GSXR 600
my switch isn't blown, but mine won't come back up...any thoughts there?
eroc263
Car: 91' 240SX Hatchback, 04' STi
Dang this was my first mod and it only took 5 mins the day I bought my car. I removed the brown wire terminal from the connector in case I ever wanted to reverse the procedure it would be as easy as plugging it back in.
nisssan-drive
Car: 1993 240sx
zerothread/93611
This may help, if you have not figured it out yet.
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
it sucks cuz one of my motors was slower then the other by like one millisecond
so if i hit the switch like 4 times fast ones a good inch lower then the other
