SLDWYS slow build 5+ years
sldwys
Car: 1991 rs13 nz new 200sx
First I got my car around 2002, 1991 Nissan 200sx with a ca18det motor, It was lowered on 16x8 and 16x9 all around, Crappy offset, Full exhaust system, Pod filter, BOV, Manual turbo, on lowered King springs. Nothing special but was a good base
Then I brought Some Lenso wheels before I knew about width and offset, A Genuine GP Sports Full bodykit, A stainless manifold + External wastegate and a GTIR turbo from a RN114 Pulsar, and some Turbo braided lines.[
about a year after my external wastegate blew off and I lost my licence for 3 months due to Demerit points, As soon as my licence was taken off me I though... Ill give the motor a freshen up with a stock rebuild. .......... The SAGA BEGINS!!
I purchased a "turbo kit" This consisted of a Ks' Rom Ecu, HKS MHG, HKS cams, HKS Camgears, Z32 AFM, Trust Wastegate, Trust Manifold and Trust Td06-19c Turbo,
Before any of this got installed on the motor I sold it haha......Brought some Veilside 18x10 and 18x9 Wheels, and some Rice tail lights....
Then in the meantime brought my girlfriend a A31 Cefiro, Gave her my wheels, And painted the car , Nothing flash but it done the job.
Brought some JIC Coilovers.... Started to tidy up the engine bay and "spray can" repainted it.
Brought some Gay-gues Then sold the Cefiro, And brought the missus a manual turbo 200sx also and brought myself some NZKW chinese seats, and some gay headlights Pics of block Rebuilt with Eagle rods and CP pistons,
Then Brought a Greddy profec b spec 2 EBC
few weeks later.... sold.... brought a prefec e-01 haha Put my JIC coilovers in the missus 200sx haha
Then we brought her a kit and got the car repainted with a front mount setup
Then brought some wide body gaurds for my car ... Finally more progress!!http://img407.imageshack.us/i/img0004zk ... 03qj2.jpg/
Then scored a Tomei Technical Trax 2-way LSD, Type X goodness , and a custom intake manifold running a q45 Throttle body,272 Tomei cams, and a few more bits....
[url=http://img63.imageshack.us/i/180sxtypex1ef6.jpg/] [url=http://img113.imageshack.us/i/newbitties006fq6.jpg/]
Then I brought some Garage-13 Headlights, They were s*** so i sold them hahaha
Brought some Work Equips , Got the panel work done and all primered, aswell as a dmax bonnet
Then I decided I needed to buy a run around... 1994 Mazda Sentia, 3l V6 RWD,
Threw on my Veilside andrew wheels... Had it for about 5 months then sold it... haha
Then... ( this just keeps going!!!!!)I brought some custom made japanese headlights semi popup they costed a pretty penny but ohwell.
and also picked up some 312/10.35mm lift Jun one off cams and a HKS cast iron manifold ( pic not of actual cams )
[url=http://img135.imageshack.us/i/wastegateflangela6.jpg/]Osgiken twin plate
HKS 50 mm
Genuine BomexKTS arms
Then the goodness.... Found this puppy on yahoo japan Hks Cast alloy iintake plenum... This was the one used on one of the formula 2 s110 Silvia super silhouettes in japan and then a week after brought that this popped up then got some FET coilpacks and a Yashio water temp gauge buddy club p1 limited edition seats
Not the real pics but i brought these same wheels, But mine are 18x10 and 18x11.5 0, +7 offset deep dish work vs-xx so they have twice the dish that these ones do
Somwhere there are alot of missing bits/pics and all....But yeah sold my gp sports kit, Brought a supermade kit, With supermade wide body gaurds, Ikeya formula Lower front control arms, Cusco strut braces, cusco c pillar braces, Rear subframe braces, Fender reinforcement braces, Cuscu rollcage, Hippo lined the whole interior whilest stripped, Stripped the whole engine bay back, Wangaan spoiler, Supermade roof spoiler, Put the work equips on my cima
Brought a house, Then the missus motor died, So just done her a full rebuild, Forged pistons and rods, Hks gt2530 turbo, Hks cams, Trust MHG, 550cc injectors, Full wire in ECU and a few other bits just about to finish putting her head back on and away we go, Will update with what her motor makes on the dyno in a few weeks time.
So mine basically sits no half im primer, waiting for me to be able to afford the paint to paint the thing and finalise finishing off my motor....
WOW WHAT A POST!!!!
Basically a full mod list is as followsNissan Ca18det DOHC turbo motorForged CP PiistonsForged Eagle RodsARP Fasteners throughoutNitrated and balanced CrankNew Nissan Oil pumpTomei 3 Layer Metal headgasket13 Hours have gone into porting and polishing the headJun 312 Deg intake and exhaust camsTomei Solid lifter setupTomei Shim setTomei Valve springsTomei Adjustable Cam gearsGreddy Racing CambeltHKS Coilpack CoverHKS Surgetank inlet manifoldNISMO quad throttle bodiesNismo ca18det Adaptor plateHKS Exhaust manifoldHKS External 50mm Race wastegateGarrett GT3582R turbo with HKS Compressor housingHKS BellmouthIkeya formula Sequential ShifterNismo Engine mounts + Gearbox mountTomei Technical Trax 2-way LSD diffCusco Zero2-R Comp coiloversKTS camber armasKTS traction armsKTS toe armsIkeya formula Front lower arms with Ikeya formula Tension/caster armsCusco Front and rear strut bracesCusco Swaybarssard 1000cc InjectorsLink g3 full wire in EcuOsgiken twin plate clutch kitR33 GTR skyline Brake upgradeNissan s15 5stud Upgradework Vs-XX 18x10 +0 / 18x11.5+7 WheelsTrust DD racing Dual stainless exhaust systemGreddy Profec e-01 Boost controllerHks Turbo timerCusco Full bolt in rollcageSupermade Full bodykitSupermade Front and Rear wide body gaurdsWangaan Drift spoilerUras Subframe lock collarsStripped Interior / Rubber spray linedBuddy club p1 Limited edition racing seatsCustom Made headlights from Japantype X tail light conversionPersonalise plate SLDWYSCurrently Being resprayed in a Bright Metallic RedKTS spin turn hand brake knobMomo Deepdish Race wheel + added on Hi boost/low boost switchDmax Fiberglass vented bonnetAerocatch flush bonnet pinsFET coilpacksSypherical balled swaybar linksCusco Front Tension BraceBomex Mirrors
BTW all work paid for/ Done by myself!!!!
Modified by sldwys at 3:41 PM 7/22/2009
Ca_Silvia
No pictures work
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
Ca_Silvia wrote:No pictures work
Yup, pictures don't work. Its like reading a book and now Im waiting for the movie.
sldwys
hmmmm i dont know how to fix it exactly.... but..... If you copy and paste the link it works?
Ca_Silvia
Top ones are working now
sldwys
yeah fail for me! Itll take me a while but im slowly going through them
sldwys
updated with pics working now... except two... because the name of the 2x pics have cars hit without the gap haha so the auto work censoring disables the links lol
Cams
2013 Scion FR-S
2016 Infiniti QX50
Much better now.
Nice job and story. Hot missus and hot 200sx's.
I also have a 200sx base car but I'm nowhere near half the things you have done to/with yours. I'll see how it is when it reaches 7 b-days with me. hehe
Keep the thread updated.
sldwys
Cams wrote:Nice job and story. Hot missus and hot 200sx's.
Hahahaha cheers yeah its taken a while... But im getting there. Still need alot more done, Will update panel work pics and all once i got some more primer on and some powdercoating done
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
so much jdm hot ness and sweet parts.......... I have to go get some water I droold so much.
where are the "final shots" with the HKS mani and ITBS?
sldwys
haha was waiting for someone to post that question up I have the ITB at home, the container full of alot of other bits of mine arrives in NZ on sunday, Its consisting of real JDM wide front gaurds, Trust DD exhaust system, The new wheels, the manifold, the coilopacks and a fwe other bits and peices
rico05
Car: 1992 RMS13 w/ CA18DET
The fact that you have a 4 port, that intake plenum and throttles, and those cams makes me hate you in a good way. You must post some sound clips of that setup at WOT.
sldwys
haha dont worry i deffinatly will do, Ill be recording the whole dyno process also
rico05
Thank you. Very, very much. I think your build is one of my favs that I have ever seen my good man.
sldwys
thanks dude, I wil hopfully be takign a few more pics this weekend as we are doing tome body work, Cant wait till monday night thats when 3 pallets full of gear arrives for me from japan
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
yo do you still have your ebay tail lights I'd buy or trade you for them if your interested I want a set to paint
sldwys
nah man sold them a long time ago
ca18detgabby
03 Infiniti G35
destroyyourmind wrote:yo do you still have your ebay tail lights I'd buy or trade you for them if your interested I want a set to paint
for what it would cost you just in shipping them over here u could buy them state side.
sldwys
your deffinatly correct there bro!!
sldwys
Small update....
Had My few pallets arrive from Japan... to my upsetness-ness-ness Only a few items onboard were actually mine.... BUT!!!
I had this arrive
And these
And Some Earls s13 --- > R32 Stainless Mesh Brake hoses
Some JDM Made Oil catch tank - Lil ghey so i might sell it lol
Some JDM Adjustable Dropjoints + Tierods
WooT wooT
float_6969
Looks great! Can't wait for the Dyno!
sldwys
yeah its taken a while... But im going to get it all finished up this year..... I cant wait for dyno time either.... Im hoping for atleast 600HP ATW.
sldwys
Crappy cellphone pics... But hey... Bit of sandblasting/polishing/powdercoating being done...got some more bits but need to start re-assembly :)
ser20det
Car: Silvia K's 88
omg .... how u found that intake kit ... itb should sound like beast.
sldwys
Small bit of an update for you all.
Fully poowdercoated intake manifold setup gooodness... annd turbo intake, Done in Natural steel color.
When I say slow.... I mean slow......
float_6969
So sexy!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Wow!!
sldwys
Im trying to figure out what color I should make the HKS logo on the manifold... Im contemplating the same red the car will be ( new mazda 6 red 3x layer pearl ) or just plain old black lettering....
On top of that I have had my whole front subframe powdercoated in a pewter grey/black.. looks really good... cant wait to get the engine bay painted and the engine back from the rally motor builder ;) f*** expensive titanium retainers are a must... so thats my next expense. On top of that the missus motor f*** out :( Rings seized up after 5 minutes of the first run :( so sad... So... We sold her turbo... Gave her my spare set of CP Pistons and rings and ditched her ACL ones. Sold her turbo.... brought somthing bigger.... haha... and its all under warranty this time should get it back in 2-3 weeks.
sldwys
Another update -
Missus Engine - ca18det 4x port
CP Forged pistons, Shotpeened rods and crank, HKS 264 deg cams, Tomei adj camgears, Greddy 1.2mm headgasket, Stainless manifold, Tomei Valve springs, 680cc Injectors, Walbro intank pump, Full 3" Zorst from turbo back, front mount intercooler and a link ECU... Paired with a Garrett gt3071Rs Turbo And she made 247kw @ 15psi of boost, ( Run in tune ) - Currently getting retuned now should have a power update for you tomorrow.
my engine
Also I have brought SlipperyTyphoons tomei ca20det Stroker crank and pistons and an currently trying to sell my tomei pistons, Tomei valve springs, spool rods and Os giken ca18det twin plate clutch...... Should be reallllly fun motor now, Once I have paid the rest of the stroker kit off ill be buying all the supertech head hardware to finish it off, Then the fuelling side needs to be done, already have a gtr fuel pump for a pickup pump to feed a ( still to buy ) twin intake surgetank which then 2x bosch 044 will feed the rail :)
Hmmm...... Alot to do if i want to get the car on the road this year!
ska69
Car: 200sx s13 ca18det
did you rob a bank or win a lottery? =)
ca20det sounds really nice ;)
I feel...stock and lame...with me trying to source stock parts to fire up the engine again.
