Skunk 2 plenum spacer.....
cheapazz
Car: '05 G35 5A/T coupe
Are they any good?? Any one running it?
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Be the first! Don't be scared..... Its skunk 2 i am sure its a quality product.
TeflonG35
Car: 2003 G35 Sedan
I doubt it will be different then any other spacer.
cheapazz
I just figured I'd ask the folks in the know if there were any problems with them. Thanks for the "go". Will let y'all know when I get it.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I have the Skunk2 5/8 spacer. I haven't had any problems with it.
zerothread/274245
cheapazz
I thought I had seen sumthin somewhere about it! Its all yer fault.
rmezz13
Be the second. Don't be scared......
cheapazz
RMEZZ...........c'mon, really?? why ya gotta kick a guy? Put me on high....then pull out the rug! Alright, I guess 2nd is better than last.
rmezz13
just because you qualify second, doesn't mean you can't win the race!
cheapazz
SWEET!!..................Just scored it on e-bay for under $100 bucks.
<------------------------how cheap am I
G_whizz
Car: 2010 G37 Coupe Sport
LOL... you cheapazz mofo!!
rmezz13
nice.... now install and enjoy..... PICS would be nice
cheapazz
Got it in, it seems to have taken some of the bottom end torque away that I gained from my exhaust but I am learning to live with it. The sound is sumthin else, woohooo. Beancooker has the pics from his install so I didn't bother with mine. Same color car, same spacer, OK....those are really my pics Anyway, it was almost as easy as the exhaust to install, we'll see what comes next.
smockers83
Car: 2006 G35 Coupe
Here's a question that's not even related, so bear with me. I just read your instructions bean and you make a point of not over torquing it or else it will cause a whistling noise. The whistling noise associated with the Pop Charger...could this be because of over torquing the hose clamps?
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
No, I think the whistling noise is created as air is sucking through the throttle body, it creates a whistling noise, when you have an inake, it opens the engine up a bit to allow more of the engine's sounds to be heard. I checked over my entire intake for leaks, and nothing... I think it's normal.
You always want to be careful when tightening nuts and bolts to the VQ, aluminum is a soft metal, and you can easily cross thread or strip your screws. get a tourque wrench, should help.
Beancooker
There are two different whistle noises from what I understand. One is from the pop charger. There is another annoying whistle that comes from over-torquing the plenum. You get a small space between the plenum and spacer, and it will cause a whistle. Not to mention, that the air sucked through the plenum gap, is unfiltered. Not that an amount that small will really matter, but none the less.
Plus just as bandaid said, the lower plenum is aluminum, and you can easily strip the bolt holes. That would be pretty bad.
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
[QUOTE=Beancooker] Not that an amount that small will really matter, but none the less. /QUOTE]
Sorry beancooker, but that small gap between the two halfs of the intake will cause problems. That air that is being sucked in is unmetered. Therefor you are getting more air into the eng. then what the mass air flow meter says is there. And by not having the propper air flow reading, you will not get the propper amount of fuel. Which leads to a lean condition. And as we all know. LEAN air/fuel ratios are BAD.
Beancooker
It would have to be a pretty rediculous gap to alter the A/F ratio to lean.
awdjdmtalon
It takes less then you think. Think in terms of a round hole here. A 1mm air leak in a Mass Air flow car is like having a baseball size hole in your tire.
Magnet 2112
Car: 2006 Infiniti G35 Coupe
Would a torque wrench help all of this and what would be the setting. Getting ready to do this mod and now getting nervous!!
awdjdmtalon
Magnet 2112 wrote:Would a torque wrench help all of this and what would be the setting. Getting ready to do this mod and now getting nervous!!
YES! The kit should come w/ the intallation instructions, to include torg. values. You can pick up a cheap inch lb. torgue wrench from your local auto parts store or Sears. Shouldn't be more then $30.00.
Geride2003.0
Car: 2003 Infiniti G35, custom Injen CAI, Skunk2 plenum spacer, custom grounding kit.
I own a 2003 G35 manual transmission. Custom Injen CAI (ram air and such), skunk2 plenum spacer, custom grounding kit.
So I purchased the display item at the 2005 nopi nationals in Georgia for about $120. I competed in the dyno contest that year and all following years with about 230 in 2005 and about 249.65whp in 2006; down to around 245 in 2007. The intake in 05 was just in short ram config. and I had a cheaper grounding kit installed. The changed for the next year was the Cold air section of the intake and a custom made grounding wire kit with a stinger negative battery terminal and 4 gauge wires. An increase by 8 to 12 whp should be a very good estimate and not some numbers I pulled out of my a$$.
I also experienced a increase in gas milage. If I had to estimate, I would say about 1 mpg, but that could be related to the increase in hp. I feel confident that I am burning more fuel when i get on the gas. :p
The spacer also works as a heat shield(sink, blocker? ). I drive without the engine cover, and I can rememmber not being able to put my hand on the plenum top after a good drive. After the Skunk2 spacer, the top would be cool enough where I could keep my hand on it for a lot longer. the top would get very hot after a few min of stand still. Keeping that intake air as dense as possible should be a big possitive for the powe hungry .
Only drawbacks include1) to be careful when installing. i would hate to think what would happen if one of the (i think 6) grommet like thinks were not in line and fell into the intake manifold. Also 2) Be careful when securing the bolts. I got a check engine light and it went away when i tightened the top bolts. Maybe only a max of half a turn for some of the bolts.3) You cannot install most front strut bars with this thing. It raises the top too high.
Otherwise, this product is awesome. I totally recommend it.
joe603
Car: 2014 Durango R/T
Excellent, thanks for posting! See you at NOPI this year...NICO has a huge tent for it, and we pwn all other car clubs!
