J-Spec Tuner wrote:You sure about that? S15 block = S14 block, s13 transmission = S14 transmission (with minor gear ratio changes).
Im pretty sure the S15 transmission bolts up, but there are some problems. First, im pretty sure you would have to use an S15 flywheel and clutch setup, hard and expensive to find, just like the transmission itself. Second, the speed sensor for the S15 is located in the rear differential as opposed to the gear case like in S13 and S14 SR's, and the final drive is different, pretty much requiring you to use the S15 differential as well. Again this peice is hard to find and fairly expensive, but at least all S15 differentials are R200 helical limited slip. Oh yeah and you would also need either a S15 driveshaft (modification might be required) or a custom one.
that would be fine if you were bolting the trans up to an SR.
there is no easy way to get the 6 speed on the KA.
