Six speed transmission for the KA24DE
jrc90240sx
I am sure you could get a T56 from a cobra, vette, or ziper to work with the KA. I would just requier some custom bellhousing adapter. The only time I feel a 6 speed would be worth it is if you where making 400+ hp. even then just upgrading to a z32 NA rear dif would give you a final drive ratio that would give you a top speed over 165, and a lower freeway crusing RPM.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The more narrow your powerband is, the more gears you need to utilize it.
s13sr20chris
jrc90240sx wrote:I am sure you could get a T56 from a cobra, vette, or ziper to work with the KA. I would just requier some custom bellhousing adapter. The only time I feel a 6 speed would be worth it is if you where making 400+ hp. even then just upgrading to a z32 NA rear dif would give you a final drive ratio that would give you a top speed over 165, and a lower freeway crusing RPM.
a t56 would be nice. they are def a proven trans. all usdm 240's have the same 4.08 rear as the z32 na. the final drive can be altered with tire sizing as well:thinker
Chingon
Car: 1991 and 1992 hatchbacks
i've heard some volvos have the same getrags as the supras. I do which we could adapt a sequential smg or smgII into our cars though. Imagine the new m5 7 spd?
s13sr20chris
heck i would love to have the m3 smgII but i have not heard of the 7 speed! thats cool!
nissan240sx92
Car: Cars
So do you think if i got a T56 with some custom bellhousing i would be able to put it on my KA motor with no problem??? Do you by any chance know what the gears are on the T56?
s13sr20chris
hit up the google bro! i would also rec that you find someone to give you a price quote on that custom bellhousing before you buy the trans.
nissan240sx92
Car: Cars
Why would i hit up goodle? Where should i start to find someone to make me a custom bellhousing?
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
um, search on google like he said.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
i wouldnt be too worried about it.
if the mods list in his signature is complete, he is gonna be awful suprised when he hits the .50 6th gear and the car stops accelerating.
toptechracing
Car: 98 Nissan 240SX race car
93 Nissan convert
http://www.quaifeamerica.com believe the UK site has a gearbox with syncros for the silvia case..
Modified by toptechracing at 3:36 PM 9/9/2004
s13sr20chris
linky no worky. one letter too many. nice pic though. look at how beefy that countershaft is.
toptechracing
93 Nissan convert
fixed
IvoryJ30t
none of the transmissions listed has a final gear taller than .8
toptechracing
93 Nissan convert
Why would you want anything taller than a .80?
IvoryJ30t
taller=numerically smaller
the guy who wants the 6 speed, wants it to increase his top end speed.
toptechracing
93 Nissan convert
with a close ratio box you could run 3:70 or higher ratio.........
Nameless EJ6
Car: What the **** do you think.
You'd be TOTALLY wasting your money on 6 gears. Do some research guy.
C-Kwik
http://www.quaifeamerica.com/gears/sylvia.htm
You'll notice on this page it says dog engagement. This means it has no syncros. If you look at the picture, you'll notice the dog fit loosely into the gears. This is to allow you not to have to use syncros. But shifting requires a very deliberate strong movement of the lever and it will be noisy as it engages. There was a NASPORT KA powered 240sx in an SCC article a while back that explained the noises they heard and the manner in which you had to shift with this type of engagement set-up. Not exactly what most people would consider comfortable.
toptechracing
93 Nissan convert
As I stated when I posted the link. I believe the UK site offers a full syncro gear set. There would clearly be advantages to a six speed box over a 5 speed depending on your goals and desires. I think to say do some research is kinda short sighted cause I think that's what this person is doing. I have rebuilt 2 of the 6 speeds from a 350z and I can see the advantage of a low stop light 1st and a tight gear set 2nd to 5th with an OD 6th for cruzin...Different strokes....
OK so I checked the UK site and they no longer offer a syncro set.
