And I get to show off my car since not everyone here is friend with me on Facebook
So to start with you will need:
a very strong piece of metal about 1"+ wide and roughly 3/16th's thick
Steel drill bit (cobalt)
Drill
Reciprocating saw with thick metal saw blade.
Once you have all of the supplies you will need measure the distance from the front of the Fascia to the black support bar that you will be drilling into in order to force the Fascia to stay up.
It shows a little less than 8" from the black bar to the front of the stillen. I just cut 8" cause im lazy but if you want to me more specific and cut it to the exact specifications by all means.
Then you will need to drill a hole about 1.5" from one of the ends of the metal. This is the location where you will drill a screw into the black bar forcing the stillen to stay up.
Once you are done this is what the metal bar should look like.
Ok now that you have one done you will need to cut another just like and you will put one on each side.
Once the bars are in place it will bend the plastic a little but your sag will be fixed
And now some of my newest mods
