This sounds like a dead battery...cazper6 wrote:** Update ** Now my car wont start. when i click the key to on. i hear my fuel pump priming. everything comes on as far as cd player, lights, blah blah. i have a oil light, engine light. and soon as i turn my car to start everything shuts off and it does not attemtp to start or turn starter at all.. and when i try it again. nothing comes on. i have to disco the battery to get it to allow everything as far as lights and stuff to come on.
This sounds like IACVhttp://forums.nicoclub.com/zerothread/251731cazper6 wrote:I have a Nissan Silvia S-14 1993 sr20de(t). I am having some idling issues. my car slowly rev's up higher and higher as its ran longer. in about 2 minutes it is running at 2500 rpm's i have untightened my tps to adjust and if i turn my tps up and hold it, the throttle goes down to normal idle around 1000 rpms but then automatically adjusts itself back up to 2300 or 2500 around that area. it seems like the ecu needs to be reflashed as it does it automatically every time. and it gets worse as the car gets more warm. also my oil pressure drops as my oil temperature will raise. maybe after 10 min. of driving it would be to high to drive any more safely. If you need. Email me at [email protected]
