Show ur oil cooler setup?!!!
tEknoS13
Car: 93' Type X
hey everyone im getting ready to install an oil cooler in my 240. its a 93' chuki with an sr so i also got a FMIC meaning i gotta make space for the oil cooler. im basically looking for ideas, pictures of ur setups for whe i do mine even though i got a pretty good idea of how to. Put up some pics
Ilvemynissan
Car: 240sx s13
I'm looking at this too, i'm curious to see what other people have.
safin
Dattebayo
I cool my oil in the fridge before I put it in the car.
Razi
Car: Moo
LOL. I drop a few ice cubes into my engine before I go on a trip.
tEknoS13
Car: 93' Type X
safin wrote:
not whati was expecting but i like
keith0486
take a look at teddy's he had a nice set up lol
240lookis
Car: 1990 240sx hatch
keith0486 wrote:take a look at teddy's he had a nice set up lol
haha, ya i remember that.
tEknoS13
Car: 93' Type X
i got my hands on this but im not sure if its good enough its rather small. let me know what u think.
it also sucks because its for push in hoses instead of being threaded.
tEknoS13
Car: 93' Type X
oh size is 11''x8"x3/4 ^^. also i got a redtop sr with few mods. this car will be a daily driver for the most part but i tend to drive like an idiot so u get the idea. and i might plan to take it to the track once in a moon
tramp_drift240
Car: 1992 240sx SE Coupe
for a chuki bumper? i say mount it behind one of the blinkers, since theres the opening underneath each one.
itll get its own little flow of air for best oil cooling without obstructing the FMIC.
tEknoS13
Car: 93' Type X
well thats where i was planning on putting it in the first place but what do u think about the size of it?
snake240
Car: 92 hatch SR20DET
if you have no a/c, take condenser out. then tons of airflow for it.
tramp_drift240
tEknoS13 wrote:well thats where i was planning on putting it in the first place but what do u think about the size of it?
well im sure youll have to reposition some stuff behind the bumper, but you should be able to squeeze it in there.
pop off your bumper and see what you can work out.
tEknoS13
Car: 93' Type X
ur right kid my ac system was removed and so was the condeser. only thing i got is IC and mitshimoto radiator
tramp_drift240
Mishimoto makes a good radiator, ive got one. good stuff, i think.
i say take the bumper off, test fitting the cooler in different locations, then just run the lines after you find where itll fit best.
tEknoS13
Car: 93' Type X
true it looks sex, and a little cheaper over Koyo. do u know anything about their fans?
safin
their fans are good too
under one of those, is pretty much the only place
tEknoS13
Car: 93' Type X
good. yea most likely i will stuff it somewhere by the passanger side duct. anyway how bout some1 else put up some pics of their setups!!
Nacho_240
Car: 1991 240sx LE
^^^ we're you planning on using a thermoswitch. It allows the oil to bypass the oil cooler during start up and then opens up when it gets hot. I've been looking into setting up an oil cooler myself but don't know where to get that switch. Any ideas?
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
rx7 oil coolers has a internal thermostat that opens up at a certain temp. I forgot what temp though.
freakyjason
Car: 1990 240sx
silpena wrote:rx7 oil coolers has a internal thermostat that opens up at a certain temp. I forgot what temp though.
I believe it opens at 145 degrees F. I remember it being kinda low.
Nacho_240
Car: 1991 240sx LE
So does the rx7 oil cooler have 2 passage ways? One from inlet to outlet end tanks and one that goes through the cooler. If that's the case, I'll be going that route.
silpena
no i think just one. I think the lower pass way is the thermo stat. I think it just opens once the oil gets hot then go to your block after wards. So both hoses will be almost the same length. IF u mount it to the farest on the passenger side front bumper then you might not need more than 2-3 feet of plumbing.
heres a of rx7 cooler i have lying around to get the idea.
rico05
Car: 1992 RMS13 w/ CA18DET
Oil filter:
Mounted to radiator face:
Complete setup:
Ancient how to I creaated:http://people.tamu.edu/~rico05/Tech/Oil_Cooler.pdf
RCA
^^^ Nice set up!
Does your kit come with a thermostat?Or is it in the picture and I just dont see it
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Air goes here
Cools down oil here
Oil goes into motor here
Nacho_240
Car: 1991 240sx LE
^^^ That is an amazing setup. BTW, You're car looks very similar to broadfield's. Both are beautiful.
rico05 wrote:Ancient how to I creaated:http://people.tamu.edu/~rico05/Tech/Oil_Cooler.pdf
Very detailed and helpful right up. So let me get this straight, if I add this thermostat:
http://vichubbard.com/auto-par....html
I'll just need about another foot of ss braided line, 2 more fitting, but wouldn't need the block adapter plate (TRD-1013) right? I'll probably be going that route now.
S13Teddy
Car: R32 Skyline, S13
Maximum air flow.
__CURRTISS__
Car: 1997 Toyota Corolla
S13Teddy wrote:Maximum air flow.
......it works tho
