He probably likes it because it starts out WAY better than SR torque curve. The decline is there yes, but you will be able to pull out of corners in lower gears at lower rpms with the great low end. The KA is obviously not trying to (and shouldn't) be a balls-out high-end-power machine. But as noted in that thread, until 5.5k rpms is where the KA will be pulling away from the SR, and if the track they race on is more turns than straight lines, by the time the SR will get to start using it's high end, the next turn will present itself, and then it's KA's turn to shine again
It all depends on the situation you are in or what you are looking for. To make the torque look a little different, you could get a turbo that starts spooling a little later, but produces more high end power, like a T04, with a large A/R, for example.Sorry for trying to put words into jrc's mouth. Just had to get this out of my system
sil80
