The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Fri Aug 22, 2014 3:35 am
I had the accelerator recall performed and I still say this sounds normal (as in due to design, as opposed to by design). Certainly won't hurt to do some transmission maintenance, and if it helps, that's great, but again, an experience of mine:
When coasting to a stop and starting to brake because getting close to the light, then the light turns green and I go to the accelerator (quickly, but not harshly). The engine revs and then acceleration kicks in after the fact. In my case, I may be going more than 1-4 mph, as the revs just seemed like first gear RPM levels, but I'm not driving aggressively at all, and I assume TDot is (so the RPM levels may match where my foot is on the pedal with the transmission between gears [I won't say in neutral because I don't believe the programming is THAT poor]). That having been said, again, there are slight differences in my experience, so TDot's experience may be a symptom of a problem, especially if it hasn't always been that way. Even if it is "normal" it may slowly cause damage, and I would certainly be concerned myself if I was experiencing it all the time, but since I normally don't drive that way, when it happens more like he describes on rare occasion when I am driving more aggressively, I don't worry about it, I just say "stupid car" (sometimes under my breath, sometimes aloud) and keep on keeping on. Then again, I know people with Jeep Grand Cherokees that down shift a second very hard downshift climbing wimpy hills, and we live in hill country. Their transmissions are have as many miles as mine and no problems (probably with less maintenance), so maybe it's no big deal for a transmission made for a Titan to experience that jarring (assuming the M35 also has that transmission).
Hopefully Svard can reproduce and get a better idea of what is being felt.
