I thought general consensus was the car shouldn't be rolled much in neutral while the engine was off. Is the transmission pump seriously connected in such a way that it doesn't pump when the engine is running if the car is in neutral?szh wrote:Agreed ... your transmission is down-shifting to let the engine do some braking.
By the way, do NOT put the car into neutral on long down-slopes. This may seem like a simple thing to do to save gas, but it actually can cause problems if the ATF is not being moved by the transmission pump while the wheels are still turning at a good clip!
Best to simply let your foot off the gas - the mileage will go up regardless.
Z
On a very steep long hill, I will shift to a lower gear. However, IMHO, the engine braking in our Ms in high gear is excessive with a capital EXCESSIVE, if a person wants to engine brake that much, they should be shifting down to begin with. Moreover, even if still enforced, I assume those laws are probably antiquated and more for standard transmissions anyway, but the opposite could actually be true. Regardless, on a hill where my 99 Park Avenue Ultra would coast up to 70MPH from 50MPH even after 180K miles (to be fair, I think GM transmissions may be designed to coast in high gear where most other brands are not), my 2006 M45 would coast from 60MPH to 55MPH, even before 45K miles, so to go down all but the steepest hills, the options are try to feather the accelerator to induce coasting or use neutral instead. I will say that flushing the J-Type transmission fluid out and replacing it with S-Type transmission fluid did help, but not substantially.myother45isalesbaer wrote:I am old school. We were taught never to coast in neutral down hill. This also a safety issue as you are not getting the assistance of the engine in braking. In many states this is in fact illegal if you get caught doing what they call "free wheeling". In fact, if its a very steep, long hill I will downshift into a lower gear just to let the engine take on some of the braking load.
Thats interesting. My 2004 M45 tends to just go faster. I don't think it downshifts when you take your foot off the gas going down hill. I have to do it manually. The old automatics wouldn't downshift either when allowed to coast downhill. I am not familiar with the newer ones. Freewheeling is an old truckers term. They used to go to neutral and lose control as the speed got higher than the brakes could handle. I still don't recommend freewheeling in any type of vechicle on steep downhill long runs. I'd rather have that motor slow me up a bit. If I want to go faster I can always hit the gas a little. I also like to know that my transmission is still engaged and if I need to go slower I can drop it down another gear. Just a safety issue. I like to be in control of the car and not let it get turned the other way around and me fighting it to get stopped in an emergency situation.The00Dustin wrote:On a very steep long hill, I will shift to a lower gear. However, IMHO, the engine braking in our Ms in high gear is excessive with a capital EXCESSIVE, if a person wants to engine brake that much, they should be shifting down to begin with. Moreover, even if still enforced, I assume those laws are probably antiquated and more for standard transmissions anyway, but the opposite could actually be true. Regardless, on a hill where my 99 Park Avenue Ultra would coast up to 70MPH from 50MPH even after 180K miles (to be fair, I think GM transmissions may be designed to coast in high gear where most other brands are not), my 2006 M45 would coast from 60MPH to 55MPH, even before 45K miles, so to go down all but the steepest hills, the options are try to feather the accelerator to induce coasting or use neutral instead. I will say that flushing the J-Type transmission fluid out and replacing it with S-Type transmission fluid did help, but not substantially.myother45isalesbaer wrote:I am old school. We were taught never to coast in neutral down hill. This also a safety issue as you are not getting the assistance of the engine in braking. In many states this is in fact illegal if you get caught doing what they call "free wheeling". In fact, if its a very steep, long hill I will downshift into a lower gear just to let the engine take on some of the braking load.
Yeah, I forgot you had a 2004, I imagine they changed this in the 2006 model, I wouldn't be surprised if they changed it back later on, like say when they went to the 7-speed transmission. It doesn't shift down automatically, though, it engine brakes that much in 5th (high) gear. I definitely engine brake with downshift in mountains, I also engine brake with downshift if there's someone in front of me, but I hate that the car engine brakes that much when I'm not telling it to. When the cruise control is engaged, you can feel it jerking on the way down hills as it taps the gas to get up to cruise speed and releases it and immediately starts losing speed to the engine braking (not to maintain speed, just because 5th has that much drag). When I said feather the gas, I meant that it doesn't engine brake if the throttle isn't at its origin, so you don't necessarily even actually accelerate in order to coast more freely, but there is very little play and the cruise control doesn't even use this "feature" (I'm assuming it's by design since you can also feather the accelerator to temporarily coast to a lower speed when adaptive cruise is on).myother45isalesbaer wrote:Thats interesting. My 2004 M45 tends to just go faster. I don't think it downshifts when you take your foot off the gas going down hill. I have to do it manually. The old automatics wouldn't downshift either when allowed to coast downhill. I am not familiar with the newer ones. Freewheeling is an old truckers term. They used to go to neutral and lose control as the speed got higher than the brakes could handle. I still don't recommend freewheeling in any type of vechicle on steep downhill long runs. I'd rather have that motor slow me up a bit. If I want to go faster I can always hit the gas a little. I also like to know that my transmission is still engaged and if I need to go slower I can drop it down another gear. Just a safety issue. I like to be in control of the car and not let it get turned the other way around and me fighting it to get stopped in an emergency situation.
myother45isalesbaer wrote:Really.....I don't think I would like that. And as Dustin says his will do it on is own. If I manually shift down, foot off the gas, it will engine brake. Don't know why Infiniti would take that away. I have to ask.....how do you like the M56. Is there anything you don't like. I wish I had the cash to layout for one. Maybe next year.
