Should I sell my car
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
so i think i wont sell it guys. to much blood sweat and tears invested in it. plus cuss words.
hugogos22
You sell your car and i will find you and kill you !
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
Don't do it bro.....don't do it.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
hugogos22 wrote:You sell your car and i will find you and kill you !
reason enough right there not to haha.....
btu i ma not going to guy.s i dont want ot miss out on all the fun i am going have in it this summer plus al lthe trouble i am going ot get into h haha.
ThuG LyFe
Car: 95 S14
i mean i would do it in a heartbeat but my car is no where like near ur car where i put in hours of work and spent time building it up. i think ur car will be more unique next to a s2000 but damn, a s2000 is a s2000. you know i love that car.
but truthfully, if i were in ur shoes i wouldn't be able to do it.
driftfan420
I'm not thread jacking... Just thought that you would like to pass him on to someone else if you don't wanna sell it for 16K..... here's a link to my car.... here's a list of mods.... tell him to show up with the check.....zerothread?id=332999
Drivetrain:
Nismo Engine/transmission mountsACT Heavy Duty 6puck sprung clutch Torque Capacity: 463 ft/lbs.Nismo steel braided Clutch lineVLSD2. Nismo Slave Cylinder and pivotFidanza lightweight fly wheel/ Fidanza Friction plateShaftmasters One piece Aluminum drive shaft W/ drive shaft safety loop
Suspension:
Tein super street CoiloverSuspension technique sway barPeak Performance Urethane Subframe BushingsTanabe Sustec Strut Bar front/rearNismo Power Brace S13Nagisa Shakitto Shock Tower Plate 240SX '89-'94 (not installed)Tanabe fender brace (not installed)
Braking Power:
Brembo slotted brake rotors ( Stock 240sx 4 bolt pattern)Hawk break padsAgency Power Stainless Steel Brake Line Kit Stock FrontAgency Power Stainless Steel Brake Line Kit Stock Rear
Engine Upgrade:
Top end:TODA SR20DE(T) Intake camshaft 264/10.5mmTODA SR20DE(T) Exhaust camshaft 264/10.5mmFerrea Dual Valve Spring Kit for Nissan SR20DETFerrea Valve seatsFerrea Titanium valve retainersPort Flow Manganese-Bronze Valve Guide SetBrian Crower Exhaust +.5 Valves for SR20DETBrian Crower Intake +.5 Valves for SR20DETER Spec Stainless Rocker Arm StoppersCometic 1.1 87mm metal head gasket,Copper Exhaust gasket,Metal Turbo Gasket,ARP Head studsBottom End:
-CP Pistons 86.5mm 9:0:1 compression-Eagle Connecting Rods with ARP hardware.-Main Bearings-Crank Bearings-Thrust Washers
Fuel System:2 Walbro 255 Fuel pumpsTomei 740cc InjectorsZ32 Fuel Filter Nissan SR20DETNGK Iridium Spark Plug Set for Nissan SR20DET (Heat 9)Sard Fuel Pressure Regulator hose type fittingLiquid filled Fuel Pressure Gauge
Power Upgrade:Garrett gt2871R turboTaka S13 SR Bottom mount Turbo Lines:w/Taka Ball Bearing Oil RestrictorGodspeed intercooler w/ custom intercooler pipingHKS ssqv BOV w/ custom pipingGreddy intake plenium (polished)Snow Performance Stage 2 Methanol KitTomei exhaust manifold (heat wrapped)Tomei exhaust elbow
Engine Cosmetics:
Flex-A-Lite model 345 Dual fansPower Enterprise Super V-Belt (Kevlar) S13SR-Belt-Set/Main,P/S,A/CGreddy SR20DET Oil PanMegan Racing S13 SR20DET Light Weight Pully SetSamco hoses ( radiator, couplers, etc.)Greddy Oil Filter Relocation Kit for Nissan S13 SR20DETMA powersteering custom line (powersteering line)Color BlueMegan Racing 1 3/8 water temp adapterCircuit sports polished coolant tankKoyo RadiatorNISMO SR20DET Grounding kit(4 Gauge)
Interior Upgrade:
2 Sparco evo2 (XL)racing seats (not purchased waiting to sell my seats)2 Willans racing harness (not installed rocking the megan harness w/seats)CUsco Custom 4 Point Roll Cage w/ harness bar Nissan 240SX S13 91-93 ( scheduled for fab and install)Roll Bar Padding - SFI Spec 45.1 Rollbar PaddingATI EZ-Pod : S13 89-94 240SXCarbon Fiber door panelsMomo Stealth foot pedalsMomo Stealth FootrestMomo Aluminum grid floor matMomo Floor matsMomo shift knobMomo leather shiftbootMomo stealth EbrakeMomo Ebrake leather bootMomo GTR2 steering wheelNRG Gen 2.5 quick release adapter (silver)Splash short boss Steering Hub
Gauges/Controllers:
Haltech E8 ECU w/ Map sensorAir temp sensorDual stage shift light (not installed)Coolant temp sensorGreddy Turbo TimerAEM Uego (Wideband)AEM TRU-BOOST Gauge-Type ControllerSaga Technik Gauges (fuel pres, oil pres, oil temp, water temp, Boost )
Audio:
2 8” Rockford fosgate sub2 10” Rockford Fosgate Sub2 6 1/2 “ Kicker door speakers4 Kicker 100watt dome tweeters1 Rockford fosgate P-400 amp1 Rockford fosgate P-200 ampCustom sub enclosure/ amp rack ( not installed in garage)Kenwood deck w/ USB connection
Exterior:
Dmax crystal rear tail lightsNew Wheel well inner cover
duffman1278
Car: 89 240sx Hatch, the wildcats!
^^^ so much readig! aww just sell it, may be drunk wiring this but do it! U'll never get it again! type oh
Kalypso
idahotuner wrote:yeah i could invest like 10,000 of it and buy a nice little sports car. or just invest it all. i suppose and seee how quick i can get even more.
a lot of stocks are dirt cheap right now. you could make a killing over the next few years.
smokerider
Car: 90 nissan 240sx
take the money and buy clean body,. go s15 and have fun building a better motor than b 4. should be fun the second time, because you know what you really want now.
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
Don't do it mang! You've put way too much effort and time into your baby!
codyace
Car: S14 w/redtop
Sell the car, and make out while you can.
THis market won't be around forever.
You've learned how to make a car on yours, now you can do the next car even better.
And, an s2000? Sure a nice car, fun (one of my very good friends has one)....but even in full bolt on range it won't be as fun as your sr car.
On top of that, mods are incredibly expensive! 750ish for a CHEAP header. 1200 bucks for an exhaust...just super super expensive stuff for them.
If I had 16k and had to do it again....
lets say there would be an FC or an FD with a LS1 in it....
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i dont know guys there is such and emotional attachment.
And plus i am having some doubts on how legit it is.
so i sent aother email and we will see.
pflicht
No just say the hell with the whole damn deal. That is YOUR car and you spent too much time making it how you wanted it! KEEP IT!
BMAR240SX
Car: 1993 Nissan 240S Coupe
Well if you are emotional about it and stuff have some fun with it before you sell it if you still want to
BMAR240SX
codyace wrote:THis market won't be around forever.
This is true but, i give it another yr until it goes to go back to normal
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
well i am pretty sure he is legit. cause he emailed me back and said that he would have his mom or dad fly up form kansas with cash and then drive it back.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
Honestly if you dont sell that car for 16 grand you are stupid. The way the economy is right now no one has any money. I know that ypu love the car and all, but these opportunities dont present themselves that often. Id sell it and build another one.....even cleaner and better...S2000's blow ***, I hate them.....
pflicht
idahotuner wrote:well i am pretty sure he is legit. cause he emailed me back and said that he would have his mom or dad fly up form kansas with cash and then drive it back.
Where at in kansas? Get on AIM!
BMAR240SX
Someone is pretty loaded with cash?
pflicht
BMAR240SX wrote:Someone is pretty loaded with cash?
Lots o' people in my area are
duffman1278
You could always wiat until the new Fast and the Furious movie comes out, then sell for more??
Modified by duffman1278 at 12:28 PM 4/27/2008
BMAR240SX
No bullshi* that is one good *** idea
Slideways^Jordan
Car: 1989 240sx Coupe-1991 240sx Hatch back
I dont think you should sell the car ben just wait untill you give it a test drive you wont want to get rid of it.
Slideways^Jordan
but you can sell it to the guy get your money back plus some and do the build agin with another 240 thats not a bad opion at all i think.
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
I would do it, but only if i had enough money to invest in a s2k and tune it up nicely. But i saw ur build forum when i came to these forums not to long ago and i loved it, it would be a shame if you sold it becouse of all the work.
I say you keep it
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
If i bought an s2000 i would supercharge it.I would have about 3 or 4 grand to do mods to it. but if i sold it i would more then likely invest the money.
i emailed him some more today and seeing wahts up.
I really dont want to sell it. started putting the interior back together. and it is going be bad ***. plus i built it to have fun and run around wasting unsuspecting cars . so basically right now i dont want to.
but we will see if his next email changes it.
Slideways^Jordan
To be honest i wouldent do it with an S2000 in mind. Sorry ben gotta look on the other brighter side of things.
I would also say to either save the money or justinvest in something like stocks and try to make more money.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
yeah i dont think ti is going to happen. i want to keep my 240
Slideways^Jordan
Thank you
now your serious right cuase id be mad if you sold it an got a honda.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i wil lget an s2000 in the future though. haha. i love those little cars. i would keep it stock. and just crusie in it on the weekends
