should i do my brakes?
240SXedUp
I just got my rotors/pads from heavy throttle (they're beautiful, ill post pics later). All ive ever done to a car is intake/exhaust install. Im wondering whether brakes is outta my league. I have no one that i know (other than you guys) that can help me with the install. So its either me (w/ the help of a friend who also knows nothing) or the mechanic. How hard would you say it is and what is the chance for error? Thanks
240SXedUp
Oh, and these, as well as my Chilton's, are what I'd been using to help...
http://www.240sx.org/links/ins...E.jpgh ... rades.html
Hijacker
Car: '92 240sx Convertible
'94 F-150
brakes are easy. IMO. The Chiltons will have it spelled out for you, so as long as you have a simple set of tools, you'll be able to do it.
240SXedUp
Yes! That's what I want to hear :ylsuper Any other opinions?
ride4lame
Its not super hard. Its all pretty easy to figure out.If you have a brain it shouldn't be hard.
The worst case scenario is you send me a ticket to Florida and i will help you with it :)
240SXedUp
Ya right... and make you miss out on that wonderful NJ weather! Id never ask you to leave :)
Seriously... are they easy to screw up? I dont care if the install takes all day, i just dont want to kill myself
Hijacker
'94 F-150
unless you somehow manage to strip a bolt, you'll be fine
InstantRice
thats always a good sign, when your afraid your mod may cause death upon installation.
He'll be on the first plane to florida, anything to escape that wonderful NJ smell. :)
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
eh knowin you youll screw it up. Just jokin just get a buddy to help bleed the brakes an ull be fine.
whiterps13
Car: white LE hatch
are you gonna bleed em or just swap pads and rotors? if its the second option it should be pretty straight forward.
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
well why not change your brake fluid?
Kiwi_S13
Breaking the bolts on the capilers brackets is always the hardest part for me. Just soak them for awhile before you try to break them and use a breaker bar. Also, your rotors likely wont just pull off. Just beatem off with a malet. Bleeding is the only part thats a real pain in the ***, just time consuming. Overall, brakes are a very simple job, I'd say it's the next step up for most DYS car people after changing their own oil, lol. Don't forget the brake cleaner if you want that ***** to stop when you're done!!!
240SXedUp
http://www.nissaninfiniticlub....1.jpg
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
I just did my own front brakes like two days ago. It was the first time for me, it was pritty stright forward. It took me 2 hours to do the fronts. I also gravity blead the fron brakes.
navysnail
you dont need to bleed if you dont open the hydraulic system. rotors do just pull off unless yours are rusted on. it is easy to do, i do it all the time in shop class. probobly done brakes like 20 times since december. read these:http://www.stoptech.com/whitep...a.htmh ... 7.htmlmake sure you break them in the right way.
Kiwi_S13
[quote=" 240kid unless yours are rusted on.[/quote]
Thats what i was refering to.
TurboTuli
Car: s13
I'll be doing my rear calipers this weekend. One of them has been sticking for a while now, but was still under warranty(previous owner replaced them last may with remanufactured) and i just got the replacements. The guy was cool and is replacing them both under warranty. How much jackstands usually cost? Know a good place to get em?
Kiwi_S13
Just remember to 'twist' those back pistons......
marshun
rotors and pads are easy. just go right on and do it. it wont kill ya
TurboTuli
Car: s13
twist the back pistons?
180fan
Car: 89 fastback
yes, twist the pistons in the rear into the casing. If you manage to press them in, you've got serious problems. The front ones press in, not the rears.
240SXedUp
Ok, how the hell do you get the bolts off the caliper. i got the bottom one, but on the top one theres no room to even get it off
240SXedUp
nvm, my mallet fixed it. i cant get my rotors off now though
Smurf6x6
Car: 93 CA18 Coupe
there should be 2 screw holes in the rotor. Screw in a screw in each hole and it should pop right off.
Demonic240
Car: Computers, Car Audio, Imports
I just put on new rotors, rebuild my calipers, and new pads last night myself. All my rotors except one came off with just my hands, the last one i tapped with a rubber mallot a few times and it came off. The rear piston is a pita to compress, you have to twist and apply pressure inward to get it to compress and get the caliper around the new pads and rotor.
240SXedUp
ok. well im getting pissed off. this damn rear rotor will not come off. ive hit it will mallet from the front and behind. ive yanked on it. it put a C Clamp on it and rotated and yanked. nothing is working
Demonic240
where in FL are yeah, maybe i can lend a helping fist ??
240SXedUp
haha na. im like 1 1/2 hours from orlando
Smurf6x6
Car: 93 CA18 Coupe
Hit it with a mallet between the lugs. Be carefull not to hit a stud. It's proberly rusted onto the spindle.
240SXedUp
^^^Thats my only guess. Its the same on both sides. Anything I can do other than drench it im WD 40?
