Shifter support bracket
95FairLadyZX
Car: 95 300ZX 2+0 NA
Has anyone made one thats unbreakable? Just curious because mine just broke and wanted to ask before I buy the oem bracket on conceptzperformance.com
A Paratroopers 300zx
Car: 1992 Nissan 300zx Twin Turbo
2004 Toyota MR-S
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
It is very legit, and on my to-do list
If you purchase direct it includes the new boots:
http://www.zspeedperformance.com/90-96- ... SP1007.htm
Z31toZ32
Car: 1999 Infinity QX4
brand new, custom designed/engineered product: http://www.zspeedperformance.com/90-96- ... categoryId. I had the chance to get one myself when Job (z speed guy) was at Ramey's house... I turned it down because of lack of cash at the time (college student) and have been regretting it ever since.
95FairLadyZX
It replaces this right? http://www.conceptzperformance.com/Cart ... .121.23.66
Just want to make sure
2004 Toyota MR-S
95FairLadyZX wrote:It replaces this right? http://www.conceptzperformance.com/Cart ... .121.23.66
Yes it does :bigthumb:
SilverTwin(OH)
Car: '91 300ZX Twin Turbo
Here's an older post of mine with a few illustrations and details on the product referenced above:
wtf-stick-shift-rubber-holder-broken-t5 ... l#p6052558
and a bit more detailed:
http://www.twinturbo.net/nissan/300zx/f ... racer.html
As Tony states above, if you purchase, go direct with Joe at www.zspeedperformance.com
Tim
95FairLadyZX
How about a replica of the oem bracket but instead of rubber, the whole thing is metal.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
SilverTwin(OH) wrote:Here's an older post of mine with a few illustrations and details on the product referenced above:
As Tony states above, if you purchase, go direct with Joe at http://www.zspeedperformance.com
Tim
Tim! Glad to see you back around these parts! :wavey:
95FairLadyZX wrote:How about a replica of the oem bracket but instead of rubber, the whole thing is metal.
Yeah, that could work too, but Joe's design is only 1234576519643 times better.
SilverTwin(OH)
It would destroy the shift linkage in short order, the shifter assembly needs to float with the movement of the transmission, hence the rubber portion of the oem mount.
The ZSpeed solid mount resolves this issue as it is mounted directly to the transmission.
SilverTwin(OH)
Thanks, I still lurk a lot. Just rarely post.
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
I have a 90 z32 TT with 108,000 miles and my shifts dont fell as smooth as they should be. Would this bracket make a differnece.
SilverTwin(OH)
fabbio25 wrote:I have a 90 z32 TT with 108,000 miles and my shifts dont fell as smooth as they should be. Would this bracket make a differnece.
It could just be an issue of worn shifter bushings if they have never been replaced. At that age/mileage you are likely due if they are original. Is there a lot of side to side play in the shifter when it is in gear?
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
Not a tremendous amount but its there. Im just curious if this bracket makes a noticible diffenernce because i was really considering ordering it.
95FairLadyZX
If its side to side then its probably your shifter bushings, I suggest you get the bronze bushings for that.If its moving up and down, hitting your drive shaft, u need a new bracket
