Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Thu Oct 17, 2013 8:16 pm
I would check for voltage at the bulb socket, then.
Yes, you can replace those with LEDs or I believe 12v micro bulbs (Radio Shack has them). I believe they should be accessible from the top of the unit, just follow the steps for radio removal but remove the climate control unit instead (or at least unscrew it and push it down under out of the housing so the top is easily accessible).
