elwesso wrote:I may have to come down there and have forecast take a look at my car!!! mmmmmm, people who know lots about the Q....... soooooo much knowledge :drooling:
wes that would be a bad idea. I know wiring, I know my way around a torque wrench, but as to why a Q would have low power ... that's a little out of my league. I just don't have the tools or experience to diagnose performance problems.
My own Q is light on power (the compression is fine, so it's probably something electronic - I guess injectors, but could be MAF, temp sensor, or even plugged cats.) Recently my Q has really started sucking the gas - I'm seeing under 12 MPG - and I don't know why.
Now, if you determined an injector needed changed or a knock sensor needed replaced, even complicated jobs like guides or cats - I can do that in short order.
Fred's happy because his brake lights work again, but I didn't really discover why he has the problem. The brake light switch is a full current switch, fed directly from it's own fuse.
The wire runs in a harness in a long inverted U, up to the top of the dash, across to the left, down pass the transmission computer and back. At the rear seat the harness goes through a connector.
All I could determine was that after the brake switch and before the connector under the rear seat there is a short.
Fred's rear seat connector is badly corroded, with a few wires 90% or more bad, however the brake light line was ok. For a really clean car, this was suprising - someone must have spilled a "big gulp" coke down there years ago.
A number of items in the dash want to know when the driver hits the brakes; the ABS control, the power steering control, the HICAS unit, the shift lock control. (and TCS & full active units but Fred doesn't have those, though I assume the wiring harness includes these points) Each one of these represents a splice off the brake line and an eventual connector.
The only way I know to diagnose this is to open the dash up and begin disconnecting the various units and checking the connectors.
