ppastos wrote:What about cork gaskets paper? Some one put RTV on the TB elbow not the main one.
Gasket and o-rings materials are chosen for a specific reason (heat, pressure, vacuum, chemical compatibility, etc.) and shouldn't be changed unless your parameters have changed (they haven't). RTV is a pain to remove cleanly without generating a bunch of debris, some of which will end up inside the TB or one of its small holes. It was a poor choice by the PO. Cork is used on valve covers so it's good for liquids and high temp but we know that cork eventually breaks down and leaks. You don't see cork used in vacuum systems either.
You're now an expert at TB with TCS removal since you've done it once and you'll find that the 2nd time around will go twice as fast. Get the correct gasket or gasket material and have at it.
