Well it all started one day as I got up in the morning and started the car and it just started shaking really bad like a bad cylinder (coil pack, sparkplug, injector).
But then I thought it could be the alternator because I replace a bad battery and thought I could have waited to long but nope the alternator was good but the guy I took it to (my dads friend who he knew for 10 years) adjusted the idle despite the fact that I wrned my dad not to let him touch it and but he said if that doesnt fix it he can put it back to where it was (or so my dad said) so now I have a new TB but need to put it in.
And this happens more when its cold I would say but I let iit warm up for 1 min
I have run Bg44k and Redline S1 but I have started using Redline more
Cleaned MAF and bent pins down and I pull the connector and ther is no stalling so there is a good connection
Checked all 8 injectors all came back good
Will check knock sensors tommorow and clean the connectors for injectors and knock sensors.
fuel pump was replaced in 2005 from the recipt and I have been using 93 octane ever since ownership
Motor mounts were replaced aroun this time:
zerothread?id=116045
Differntal fluid was changed 1 week ago
Fuel filter was changed recintaly I will change it againg because its cheap.
I have a boat load of recipts from preivious owner so feel free to ask any specific questions but I have too much to list.
