I don't know how much power my future holds. Possibly 600-700. But thats a long time away.StricNyne wrote:well i havent run mine, BUT it looks ****ing amazing lol i mean i was surprised, how much power you plan on making where your tearing u joints lol, and i believe they are steel
They seem to sell the Rb25 s13 driveshaft with the correct yoke already installed. Plus there prices are Much better than Driveshaft shop's.uber95 wrote:If you are breaking U-joints driveshaft choice won't matter. Aluminum D/S are the factory choice on many high HP cars, no worries there. Although I don't have a ShaftMasters D/S I'm sure they are more than adaquate for what you need. The U-joint issue can be addressed with some high quality spicer units. You will need to have a new yoke made I'm sure with the appropriate provisions.
Yes. They will tell you where to measure to / from. My shaft is a 'custom' due to the combination of cross-member and differential that I am running.rb25drag wrote:Also does it matter what crossmember im running?
I wouldn't mind the q45 except I don't wanna change my brake setup I just spent 900$ on. I would rather just buy axles and be done with it. Plus I have already welded the spider gears up for the Full posi.Shocker wrote:I'd put a q45 rear end and half shafts in before I upgraded to crazy one off axles. They seemed to work great for Riggs, as he was breaking Mazwork's axles....
Your not kidding. I want to hit the track but if I get teched they won't let me race. There are a handfull of problems that need addressing before I even attempt to go.rb25drag wrote:
I guess Im asking for too much too cheap!! LOL I just wish I didn't have to break my bank account everytime I wanted to go race a night.
Nice, Thanks for the post. I think I would feel more comfortable with a steel shaft. I know aluminum is strong. But I want it to last for years to come.silviasgp06 wrote:i ordered a steal one from them, you just have to call to order it. 317ish shipped. called and talked to them and mounts do not matter, they said out of all the ones they have made all mounts are all with in 2 to 3 inches of each other for the shafts length. You just specify if you have a abs or non abs differential.(abs version like the s14 VLSD requires a slightly shorter shaft) No problems with it so far, and they have had customers that drive the steal and aluminum in 500hp plus drag and drift cars with no issues yet, have been driving for almost 4,000miles with it.
oh and they are fully re-buildable
prices will always fluctuate a little, its just the day we live in now.
LOL, I agree. Luckly my local track doesn't tech you until you get to 7.50's in the 1/8th. Which I have been warned since I don't have my cage in that they will throw me off the track if I run that number. Last time I was there I went 7.80 and I had 2 guys briefly looking at my setup. So I know of a bunch of things I need to get but can''t $$$ it.240z4u wrote:
Seems like Ill never make it, always something on this freakin car!
No dumping of the clutch. Thats why I bought a Stage 4 Cusco Exedy Twin Plate Insurance!!240z4u wrote:MT slicks at the track, two piece driveshaft... your car is hooking because the tires are sticking but there is no weight transfer to offset the hard shock to the axles.
Do you dump your clutch, you should definitely not be if thats the case.
Evan
How much play is in your clutch? I cant imagine being able to do that with my 6 puck... its pretty much on or off... I might have to try tho, seems like a good idea.rb25drag wrote:
When Staging I Pre-stage, Set my launch control bring up my rpm's ease into the 2nd stage, then I slip the clutch with the E-brake on to pre-load the drive tran so I don't have any slack when launching then she either goes or breaks.
I believe Andy (Booztd3) started having issues with them around 600 whp. If memory serves, he damaged a 2-3 synchronizer. Everything is internally identical to a Z32 NA trans. He did a nice writeup on this too.rb25drag wrote:How strong are the Rb25 transmission's? Should I worry about breaking it?
