Why are you posting this?QR25DE wrote:http://www.speedforceracing.co...ystem
Have fun.
For sedans, just modify piping for the coupes. It's pricey... lol
Modified by QR25DE at 3:19 PM 1/30/2010
Interesting, didn't know the UpRev stuff supported the 2.5L, from their site they support the 350Z with the 3.5L...dldjros69 wrote:I tried to take your list of parts to one company and they totally blew me off. this is of course after i went to them about 6 months ago for them to make me a custom turbo set up. they quoted me 8 to 9 grand. im not sure why i tried to give those jack @sses another chance.
Well i found this place in Lansdale Pa called RT tuning and they found this kit and said they would be happy to do it. i didnt even know this kit was released until they told me.
My kit is being built with out the Apexi neo though. I am getting an up rev reflash with dyno tuning. im really stoked about. im having trouble sleeping.
Anymore info you can give me on this?
Yep, I think they know from the PDF I found on their site for supported car but each ECU might be different. It'll be the same with the BullyDog tuner with the ZNXXA serial codes/model numbers to right the programs for.dldjros69 wrote:
Yup
the head dude at the shop connected his laptop to my cars obdII port. He copied my ecu and called it a rom dump. He sent the info to uprev and they said they will have tuneable program of the factory ecu. (or what ever the heck its called). i think they are gonna crack the code and enable my guys to tune the factory ecu.
The rt tuning guys said this is better than a piggy back because there is no need for correction - leaning or riching the fuel. Its exactly correct at all times.
they also said that the guys at uprev were really excited about getting a copy of my engine map because they want to release something for our cars and they want to get more involved in our cars.
Hope that helps - (also i usually say this - i have no idea what im talkin about, i hope i got it all correct)
Hit and miss, the CVT is s***. Some people have it fail without boost. Take your chances.migs7585 wrote:could the cvt even handle this set up?
Cool I emailed them earlier, i'll see what they say. I doubt anyone in my city is certified lol. We're lucky if we can find a shop that tunes cars properly... only know of 1 good shop lol.dldjros69 wrote:Yup id assume it will be the same thing as with the bd tuner. 40 different engine codes.
i can do 2 things for you.
1. say something to my guys and see what happens
or
2. (i had the brochure stuck in my couch cushion)
http://www.uprev.com
[email protected]
512 538 4856
Then you would have to take your car to someone who is uprev certified and they can hook a "cipher" cable up to your car. Its 300 dollars for the uprev license (flash) and 175 dollars an hour for tuning. Those are my prices not sure what u can work out.
Hussain wrote:PLUS the CVT in the 2.5s is supposed to be not even half as good as the 3.5se CVT.... so its a guarantee that the transmission will blow on the 2.5s CVT.
UpRev e-mailed me back saying the exact same thing you got told. They will need a dump of my ECU. To do this you need to purchase the Osiris Tuner ($700 USD). Once you dump your ECU, send them the dump file and they will work with you so it will work with the UpRev software.dldjros69 wrote:Yup id assume it will be the same thing as with the bd tuner. 40 different engine codes.
or
[email protected]
512 538 4856
If you have time to wait forthe turbo kit, you should get everything else running. At least get the UpRev flash installed and tune for the bigger injectors. Then once the turbo kit is here, it's bolt on and adjust A/F and you're done.dldjros69 wrote:Update - just got off the fone with the guys from rt tuning.
they said uprev finished the patch and everything is ready to go.
Bad news they didnt order my turbo kit yet, because i didnt give them a deposit. Even though they said they would order it. Oh well the check from my credit car will be here in 3 days, and they can order it then.
i caught that and so did they.QR25DE wrote:Oh, that kit is a basic kit I found out. When you ordered it did you tell them it was for a coupe? I assume you'll either have to cut a lot of piping or won't have enough.
I wouldn't go 10psi on stock internals. It's probably fine but borderline. At LEAST get valve springs. The piston rings are pretty thin/s***ty too so blow by isn't good. I dunno. 7 pounds is a safe bet and even then things can break if it's not tuned right.DaCoupe wrote:Wow finally a kit out
So could you safely raise the boost with this kit to something higher around 10 , or would you have to buy the upgrade parts they're suggesting?
they said if i wanted to go higher they could install a manual boost adjusterQR25DE wrote:Now I gotta bump mine up to 8 just to beat you.. rage. lol.
