Setting VH45 Cam Timing
Ezekial
Car: 2001 Nissan 200SX S15
I did a search but found nothing
Anyone??
Raxephon
Car: '04 RX8...for the moment...
Not sure if this is what you're looking for or not, but its cam timing related.
zerothread?id=140310
Also, when setting the timing, have the crankshaft set at TDC and the camshafts set so that the cut-outs in the cams for the headbolts are facing towards the center of the cylinder head.
Cyl#1 camlobes are opposing when Piston#1 is at TDC.
Ezekial
theres a dot on th cam geaars thhy myust line up qwith somethhhhinggg on the head or yeh ,n;block
Raxephon
Ezekial wrote:theres a dot on the cam gears they must line up with something on the head or the block
Is this the dot you mean?(Circled/Squared in red)
If so, thats for one of the silver links on the timing chain.
Modified by anlasak at 6:32 AM 12/30/2005
Raxephon
'94 FSM Timing chain install snips
Raxephon
Close-ups
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Good info!!!
Ezekial
Thanks heaps mate!!
Ezekial
This would be the reason I need to know about cam timing
elwesso
2007 BMW M Coupe
Ahh, sans chain guides. not good!!
Ezekial
i cant believe the oil pump gear on the crank rely's on the pulley to stop it from free spinning
ie. no woodriff key
Ezekial
elwesso wrote:Ahh, sans chain guides. not good!!
ahhhh what can ya do ... the chains were still tight ... until i removed the tensioner on the 1-3-5-7 bank ... then the lower RH guide snapped completely
the 2-4-6-8 bank chain was still tight even with the broken slack side guide
so i'd say my valves are ok ... just need to put the new guides on and then do a cylinder leakage test on each to make sure no bent valves before it goes back in
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ezekial wrote:i cant believe the oil pump gear on the crank rely's on the pulley to stop it from free spinning
ie. no woodriff key
Why you need to read the FSM and all the previous posts by Q45tech. There is a very good reason the crank bolt is torqued to 270 ft. lbs., or whatever the specification is.
Ezekial
well that would help but still ... if by chance it comes loose ... not only do you shear the woodriff keys but you lose oil pressure!!
full length woodriff key cut into crank the first opportunity i get
Raxephon
Ezekial wrote:Thanks heaps mate!!
You're Welcome.
Maybe its just me, but are you missing the timing cover sections of the headgaskets?
maxnix wrote: There is a very good reason the crank bolt is torqued to 270 ft. lbs., or whatever the specification is.
353-373 N.m36-38 kg-m260-275 ft-lb
Ezekial
timing cover sections of head gaskets??
Raxephon
The front half of your head gaskets, (the section that goes between the lower cover & the upper covers), look like they are missing.
Ezekial
so i guess its safe to say the front covers have been off before at some stage and the head gasket has been butchered
well that settles it then ... off come the heads
qsiguy
Car: 1994 Infiniti Q45 Turbo
Been searching for a while now for info on fine tuning the timing, this thread seemed to be very informative but I'm quite sure I dont' need to mess with the cam chains to tweak the timing. Can someone provide some info on how one would change timing from 15 to 17 or vice versa, or say it was at 14 and needed to move it to 15. You get the idea.
Raxephon
qsiguy
Awesome, that's what I've been looking for. I must be loosing my mind. I looked at q45.org and totally missed it.
Thanks
