Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Jul 07, 2003 9:34 am
Got an interesting call from a large dealer in Atlanta. During the winter they had rebuilt a 92 Q engine using more than $4500 worth of retail parts [and 55 hours of labor][to keep their Master tech earning when things were slow] [he worked for us for 5 years by the way].........because they could not find any suitable 90-93 engines to do swapouts.The Q owner backed out of the deal and junked the car for parts.
They have had the long block motor sitting for 4.5 months and offered it to us for $2500 their actual cost might have been $3,900-$4,300.
Even at $2500 it is still too expensive to use to keep within a $5500 price range -- very very few owners contemplate spending that much now on a 90-93 engine swap.
You gotta be careful about any engine replacement the only way is to change everything while the engine is out and easy to work on, otherwise you get nickeled and dimed to death in the years following the swap redoing all the old accessory parts/hose/sensors you neglected to change.
Shops can't warranty what they don't change and 99% of the time what they don't change turns out to be the future problem.
Many just low ball the swap and change nothing hoping they make 12,000 miles or less and tell the owner hey we didn't change that so it wasn't our fault ..........sure they charged $1,000 less but the engine [system] now needs another $1500 and will need another $1500 next year.
Don't always take the low bidder unless you know exactly what is occuring. An extra $500-$1,000 spent on the swap while the work is easy can save you $2,000 when it must be done again with the engine in the car.
