Quick light off cats welded to the exhaust manifolds [headers] inches behind the O2 sensors. To take care of some HC emissions after the first 30 seconds - 2 minutes of startup [cold start emissions].
The core expands when hot to offer little back pressure then. The main cats are a few feet to the rear.
http://www.aecc.be/en/current_technology.htm
http://www.engin.umd.umich.edu....html
A large engine like 4.5 produces twice-3x the amount of exhaust gases at idle as a more conventional 4 banger.
Proper long lived emissions system would have at least 4 cats some newer models have 6 cats.
Prior to 2000, The JDM engines only have 2 cats [no precats] but the main cats are larger and more expensive.
Removal [punching out] the precats offers only a tiny increase in performance but it screws up the O2 sensor/ecu calibration at 2,000 rpm cruise making the ecu enrich the mixture more than is necessary.............highway mileage drops by 10% or more and it is tricky to get a emission test on a dyno to pass in cold climates when it is below 70F ambient..............don't ask how I know but the hint is my Birthday is in Jan. so that when I get tested.
THE JDM takeout engines all come without precats so you must swap the old engine's exhaust manifolds to become US legal.
Side by side testing of an illegal JDM with my engine/car 2 years ago [both with JWT ecu] indicates at most a 1 car length advantage by 120 mph...................most of that or more probably had to do with the differences in mileage.......better compression.
32 valve engine are very very bad polluters at low rpms because of the large valve area.........US 16 valve engines tend to be more optimized for low rpm so they can save some money on cats.
After 1996 OBD2 most have two cats per bank of cylinders.
