dhen wrote:OK. Do you think they can flush out the oil pump, too, or is that too big of a risk? It has almost no miles on it.
As said before, take it apart, inspect it as per FSM, if anything, ANYTHING at all looks fishy, or out of spec, replace it. I'd be suprised, if it would be OK after this.
If your budget does not depend on that $160, though, just buy a new one, don't take any risks. It's too important a part.
dhen wrote:PS This may be a stupid question, but if I need a new block, I want to get it bored out to 83.5 mm rather than my current 84 mm. Can I reuse the wrist pins/locks if I have Wiseco pistons now but go to a different brand? I'm thinking about getting Supertechs.
You'll get new circlips/snap rings and writs pins with a new set of aftermarket pistons, so you don't need to worry about this.
dhen wrote:Did I put these bearing caps back correctly? I forgot to pay attention to which side the numbers were on when I took them off. I didn't see anything about it in the manual, but I rebuilt a differential once where that was critical.
My vote is on backwards, as well. If I remember corectly, mine even had arrows on them. Or at least one of them.
Too bad about this whole thing, wish you the best of luck!
