mrodrig2 wrote:QR25DE wrote:They will not work. While they may physically fit (unlikely), the timing will be off on both intake and exhaust due to the "redesign" of the motor. The valve springs are even different. I do not think most companies realize this as of yet and that's why nothing has been developed. You're welcome to get them and test them out though
! hahaha.
Altering the timing is the whole purpose of replacing the cams. Different doesn't mean it won't work. You would obviously not just drop the cams in without wanting to dive into the computer.
Really, that didn't occur to me...
Cams MADE for the motor will work, not cams made for a slightly different motor with different compression, timing, different stock cams with different lifts and durations.
I know all about cams as I built a motor before with Crane cams for my Neon back in the day. If cams are going to be made to work they will need to be designed around this revision of the motor and not the 06 and earlier versions.
Again, while the cams *may* fit, they may not perform optimally (even with tuning) as they are not designed for this motor.
Here are the main differences between 07+ and 06 and earlier and the SPEC V versions.
1. Standard 06 and earlier valve springs are weak.
2. Standard 07+ valve springs are weak.
3. SPEC V 06 and earlier valve springs are preferred.
4. SPEC V 07+ valve springs are preferred.
5. 06 and earlier Balance Shaft is different that 07+. The balancer system has been moved back slightly from the crank pulley to a more central location in the block. This also means JWT's balance shaft removal kit for the 1st gen QR will not work.
6. 06 and earlier use a different spark plug than 07+.
7. The ECUs are different between 06 and earlier and 07+. -- Thus Uprev supporting 07+.
8. Power valve screws in the intake manifold may become loose and result in unstable idling or power loss in 06 and earlier. This is fixed for 07+.
9. A simpler, larger diameter single path resin intake manifold replaced the old dual path design. No more troublesome butterfly valves with screws that came loose and got ingested.
10. 07+ Revised piston crown shape to support a higher compression ratio of 9.6:1.(10.5:1 in Sentra SE-R Spec V.)
11. 07+ Revised cam shaft profile.
12. 07+ Reinforced connecting rods.
13. 07+ also has a higher rev limit.
The main things to be concerned about would be using cams designed for the 1st Gen in the 2nd Gen motor due to the different stock intake and exhaust durations. The after market cams are designed to be more aggressive than stock, not more aggressive than stock on a 2nd Gen. It's different.
If you want to try it go ahead and let us know the results. I'm basing this of what I know personally and what I have found online with research before I boosted mine. I abandoned this idea due to all the differences. Many sites that sell after-market cams usually mention *not compatible with 07+*. You would also need strong valve springs. With more aggressive cams the lift and compression on the springs may be too much for stock (depending on how aggressive you go) and cause the valve springs to snap. When that happens usually the valves will smash into the pistons cause the piston head to EXPLODE IN A FURY OF CRASHING AND DESTROYED ENGINE GOODNESS!
My opinion/conclusion: Wait until 07+ cams are made or get a company to custom make them for you.
This is what happened to my piston in my Neon with Crane 16 cams and Crane valve springs... should have replaced them with Crower springs but lesson learned:
Before:
After:
At least the rods were good... lol
