fo0manchu »
https://forums.nicoclub.com/fo0manchu-u4272.html
Mon May 26, 2003 2:46 pm
If you guys haven't read up on alcohol injection yet, do a search on google and read up on it. It is awesome and a cheap mod to add when boosting.
You can get denatured alcohol at your local hard ware store. Its about 10 bucks a gallon over at home depot. And you wouldn't be running 100% alky, it would be more like 50% alky and 50% water.(correct me if I'm wrong) And you can set the solenoid to spray alky in at whatever rpm you wish or at certain boost levels. So you wouldn't be running alky all the time when your just cruising around town.
I also heard that alky cleans off all of your carbon deposits in your engine internals!
I'll be using alky injection when I go turbo for sure!
