OK so here's the deal. I went to get the seatbelts checked in August and the service writter said they still retracted but slow. He wouldn't let me show him my issue when I unbuckle the belt just sits there until I give it some assistance. He also said they can't do anything unless they completely do not retract. I was a bit ticked off to say the least, what do you think I should do?Towncivilian wrote:Did either of you guys go through with the free seat belt replacement yet?
Alkorahil wrote:If your local dealer is giving you problems on seat belt replacement under warranty give them this information including the Op Codes, this is straight from Nissan.
WARRANTY COVERAGE
PLAN SB
Seat Belts - Useful life of the vehicle for 1989-2002 vehicles, 10 years for 2003 up vehicles.
OpCode VK22AA Replace Front Seat Belt Tounge Assembly - One side
OpCode VK213AA Replace Front Seat Belt Tounge Assembly - Both Sides
If you take your vehicle to get seat belts done, and they say it is not covered, tell your Service Advisor to contact their Warranty Administrator and give this information, if they do not cooperate call 1-800-NISSAN1.
That's what happened to me, so i just drove to the nearest infiniti dealership.wisehunter1 wrote:I also went to the Nissan dealership and the advisor told me that Nissan cannot perform manufacturer warranty repairs on my Infiniti.
Thanks for the clarification. That does make my case a little stronger.Towncivilian wrote:This isn't a recall, it's just warranty. Your seatbelts are warranted for life and ask for your service adviser to replace them because of a failure in the seatbelt pre-tensioner. Give them the opcodes mentioned above.
I thought the same of the new seatbelts. They are much more comfortable; it's almost a pleasure to wear them now.Bambritt wrote:I just had mine replaced, no problems at all and no cost. The belts do seem to be slightly different, the thickness and weight of the fabric seems less. Im pleased with the new belts as it feels like Im not wearing a seatbelt and there is no restriction when I move or adjust my position while driving.
