raging panda »
https://forums.nicoclub.com/raging-panda-u4045.html
Fri Jul 29, 2005 9:47 pm
I used to have a sparco sprint, and a sparco speed. If you are under 6 ft, its pretty good fit, but some guys just aren't comfy in the bottom mount seats. I moved up to a pro2000, which is both bottom and side mount, im using bottom mount right now and with all the padding removed, its holds me super crazy style, and its really low seating position. For the price, you really cant beat the sprint, its a good seat and I like them, most of my friends use those seats, all bottom mount, all run events with helmets, all fit just fine. One guy has to run without the sliding bracket though to get really low. Try a bottom mount in someone else's car, if you don't fit, then you have to shell out the money to get a side mount seat, which usually start around 500 and up from what i've seen.
