capncash wrote:1994 Q45. The memory buttons (#1 & 2) on the driver door are both blinking ALL THE TIME, even when car is turned off. I cant set the memory and cant get them to go off. Also the steering wheel stopped moving yesterday when I turn the car off. Any ideas?
There is a weird process for re-activating the memory function that controls the automatic seat/mirror function. I forget eactly what it is, but it involves turning the ignition on and off and opening and closing the driver's door several times. Maybe someone has the exact combination of how it needs to be done. It's goofy, but it works. Also, be sure that you didn't inadvertently turn the auto function off by bumping the on-off switch on the steering column, maybe when you looked for and/or changed the fuse for the cig lighter. It's easy to do by accident.
Not sure about the memory lights blinking, especially when ignition off. Try resetting the body computer by disconnecting the batt cable and waiting a few minutes as suggested. That will also remove all other memory settings, like seats, mirrors, radio, etc, as well as the ECU, which will have to re-learn your driving techniques afterward before it settles in. Until it does, you may notice a slight reduction in performance, fuel mileage, and shifting, but it will return to normal after a short time.
Be sure to let us know how y6ou make out so others can learn from your problem.
