Steve Lloyd wrote:
So why then did the Nissan engineers design the front of the T to hook up to the intake?? You must have a magic engine if you can get vacuum from your valve cover. Every vacuum source I've ever seen on ANY engine is on the intake. The valve cover has no way to create vacuum like you illustrated in your picture. Do you understand how the PVC system works?? There is a check valve in the PVC so that air doesn't flow INTO the valve cover area, so why would the catch can system blow INTO the valve cover?? Aslo, if the valve cover created vacuum(suction) how would the check valve ever open?? The valve cover is pressurised(blows air) and the PVC system relieves this pressure.
Jesus dude. Look what the PCV line runs to. The Intake manifold. Vacuum pressure is located there. Its not a magic engine. Look in the picture. The stock oil catch can is located at the back of the T. Crack open an FSM and look at the Vacuum Diagram.
This is what you said- "Every vacuum source I've ever seen on ANY engine is on the intake."
My response- I say again, Look where the PCV is hooked!!!The Line from the valve hooks directly into the top of the intake manifold.
This is what you said- "So why then did the Nissan engineers design the front of the T to hook up to the intake??"
My response - To burn the fumes from the crack case. The whole purpose of a catch can is to separate out the oil so that the fumes can be burned in the combustion chamber. The vacuum created is greater than the pressure of both the crankcase blow by and valve cover blow by combined. Without relieving this excess vacuum problems would occur.
Why even have those oily fumes flowing through your intercooler/intake in the first place? When the fumes can be sent the same way the fumes produced in the valve cover are burned.
Just hook the catch can like I said so the fumes flow through the valve cover through the pcv and into the combustion chamber via the intake plenum runners.
This will save your Intercooler and inlet turbine from getting mucked up.Remember this. Fumes still contain residue from whatever it burned off from.
Just a little FYI, I do know how a PCV works. The question is DO YOU??Obviously not by this statement.This is what you said - " There is a check valve in the PVC so that air doesn't flow INTO the valve cover area, so why would the catch can system blow INTO the valve cover?? Aslo, if the valve cover created vacuum(suction) how would the check valve ever open?? The valve cover is pressurised(blows air) and the PVC system relieves this pressure."
My response - Taken Straight from the PCV section of my LS1 ASE Engine Performance Booklet
The PCV (Positive Crankcase Ventilation) valve (along with the Breather Element) re-circulates unburned gases back into the engine to be re-burned, cutting air pollution. A plugged PCV can cause rough engine idle and many other problems, including engine damage. It is quite important that the PCV value be working properly in your car. The PCV valve should be checked/changed every 30,000 miles.
First off lets look at the work check valve. This allows air to flow only in one direction. "how would it ever open" A check valve is always open unless air flows in the direction that it is not supposed to. It then closes to prevent this.Check Valve means one way flow. Sigh....
Next, Positive Crankcase Ventilation. Let's take a look at this. Hmm... How bout this helps ventilate the fumes/blow by gases created in the crankcase.
"Valve Cover is pressurized" Yes and No. Pressure is created by blow by from combustion, however the vacuum created by the intake manifold sucking on the PCV is greater. So that the unburned fumes can be recirculated back into the Combustion chamber to be burned to reduce pollution.These same fumes are "blew by" into the crankcase creating a positive pressure. Hence the need for a Positive crankcase ventilation system.
Seriously dude if you don't know what you are talking about especially something as simple as a PCV valve do us all a favor and don't give anyone mechanical advice.
I'm ASE certified. I know who's right and who's not. Do whatever you want. I'm not going to argue anymore.It's not my car.
On to the next topic.Peace out.
Modified by Tr0uble at 2:40 AM 8/18/2007
Modified by Tr0uble at 2:45 AM 8/18/2007
