Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Tue Jun 14, 2005 3:57 pm
correct, for the oil (crank case) part, you should make sure the car is in running temperature, turn it off, dump 1 pint of seafoam into the oil, let it idle for 10 min and do an oil change.
if try to drown the vacuum line from brake booster into a cup of seafoam, your car will stall. In some cases I heard you might even hydrolock. So... just let it take small sips with plenty of fresh air. If you are using a straw like me, make sure you bend the straw a little so it doens't get sucked in as well. Um not like it happened to me but I can just imagine someone doing that.
