ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Fri Mar 26, 2004 10:20 pm
I'm sure everyone's tired of people asking about chain guides with the early Q45. I have a 92 Q45a that I'm wanting to put under the wrench for some fresh guides. I called the dealer in Des Moines and they said it would be $2100 in labor alone. They also said that it's basically the same as replacing the chains too. I says "BS" and that was the end of the conversation. Kansas City dealer quoted $2500 or so. I live in southern Iowa and don't think there's much option but to try it myself. I'm rather good with mechanic stuff and have built some domestic V8s and done the spark plugs on the Q. The plugs weren't too bad and just took a little patience. From what I understand, the critical moment in the chain guide replacement is when the motor is first started and there isn't oil pressure to the tensioners to keep the slack out of the chains. Is there an easy way to pressurize the oiling system before starting the car up when the new guides are installed? I was thinking maybe a tapped and plugged passage to an oil galley that I could put a fitting into with a hose connected to my old crown vic which I could start up and push its oil into my Q motor. What parts do I need? Do I need new hydraulic tensioners or can I use the originals? If so, I would just need the guides, longer bolts, front cover crankshaft seal, oil pump guides, and oil pump chain, correct? What's the best way to keep the chains from jumping the sprockets during the guide replacement? How about using a thin wire and wire the chain together under the cams to keep them from going too slack in the midst of the deal? Guys that have done this, does this sound like disaster waiting to happen or a reasonable plan? If there is no oil passage to connect with a hose fitting, could a oil filter be tapped and thread a fitting into it and pump oil into that? As for the front cover, all that needs removed is the lower one piece cover itself right? Does the alternator, power steering pump, A/C compressor, water pump need to be removed? I can see that the idler tension pulleys will need removed, but that's no big deal. As for changing the oil filter, I've just been taking the 4 10mm nuts off the fan and removing the fan to get to the filter, is this the regular way of doing it? Where's the best place for me to get just the needed parts for this job? If it's not something I should try, is there any good places between Kansas City and Des Moines/Ames that will do it for less than $2000? I kinda wouldn't want to take it to Des Moines even if I had $2500 because the "most experienced tech" obviously doesn't know what he's talking about, much less doing with this chain guide issue. Oh yeah, I'm new here but have been reading on and off here for the last several months, great site. ThanksScott J.
