ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Fri Mar 26, 2004 10:20 pm
I didn't want to wait for something to go wrong to fix it. I'm that way with many things but not stuff like the chain guides. My guides were all perfectly intact, including the driver side guides. I did get the slack side guide out by rotating it inward after removing the aluminum bracket that holds the adjustable oil pump chain guide. From there it was smooth sailing. I've got zip ties on both sides, have heard no cams snap, all the guides are out, and the chains are both pretty tight. Azskygod has better pics than I've taken. I did notice that the oil pump nut wasn't on all that tight with mine. I'm gonna torque it down a bit more than it was before to be safe. I know I'm not outta the woods yet, but it is starting to look more promising and if I can save $2200+ I'll be thrilled. So, guys that have done this and been ever so helpful, now that the guides are out and the chains are tight with zip ties and no cam snappage, am I over the pinnacle? Zenith, peak... whatever? My head gaskets that seal the top of the front cover are chewed a little on the surface from when I removed the cover, what's the best way to fix it? Should I just remove the loose gasket junk, add some silicone and put the front cover on and then add some more silicone to the outside of the seam? I don't mean a lot of silicone, I know that's a no no, just enough to coat the roughed spots... Also, I took my leaky power steering hose from my 91 Q to a local hardware place and got it fixed up with new 3/8" hose and crimp clamps. Seems to work great and the $13.00 it cost me was a lot cheaper than the $157 for a new one.
