tryiian »
https://forums.nicoclub.com/tryiian-u16831.html
Thu Oct 13, 2005 7:33 pm
Hey guys, I don`t understand some things here. For where it`s relevant, i`m planning on using a bare-minimum setup for whatever little kick I can get out of it for cost effective power:t3/04e 50 trim .63 a/r(I wanted to use a t28 but quick spool = too quickly for mileage driving)some average sized fmicsr injtial 38mmSAFCNot sure if a BOV is an essential part of a turbo system or not yet... if so, whatever used bov I can afford, too.
Question #1, How does an safc work?: FMU = fuel management unit, i.e. SAFC? What this does is control the fuel pressure, and through that, how much fuel is going through the stock injectors and pump? Or is an adjustable pump necessary to use the SAFC? Where does an SAFC hook up to to control the fuel flow, the ecu?
Q2 necessity of Inj/FMU/RRR/FPR?: For 8psi max, (my planned weekend boost, on an all stock engine) I was planning on running sr injectors and an SAFC. Would that flow the right amount of fuel? Do I need the adjustable pump anyway or instead of the injectors or both?
Q3 Do I need a wideband+dyno tune for saftey?: I hadn`t planned on getting extensive tuning, due to expense, I was gonna take whatever I got out of SAFC tuning and retarding base timing if necessary. What on my car would be tuned if I was to take it to a dyno and have someone who knows what they`re looking for adjust things by getting wideband readings? Would this tuning be necessary for the safety of the engine or just to increase power?
Timing management Q: Not fuel related but, for 8 psi, will I need any form of timing control, like the BTM or emanage? Also, I`m not up to date on all my turbo info (like I needed to say that after exemplifying through all these questions) so can boost level be controlled by something mechanical/hardware related on the external wastegate (like the tial 38 that everyone uses)? Or do I need something that controls boost "electronically"? I`m likely not using an MBC after reading about reliability problems with them.
Safety monitoring q: I understand how the EGT would be a good way of figuring out the average condition of your a/f and seeing a problem that way and how because it would be gradually affected by changes in afr that could happen quickly in the engine, so what would the best (affordable) method of monitoring the AFR be? Is a narrowband a/f system the same as any "a/f gauge"? and doesn`t the safc monitor knock in realtime? Wouldn`t that be all that I need to monitor how my KAT is doing?
I know I`m probably being selfish by askin for so much in depth explanation but even in all the threads and writeups I read, it`s still very difficult to get an explanation to every question I have, and answering this stuff would likely help a lot of people who are in a similar situation of ignorance as me.
