safc2 wiring help, maf not reading :(
snags
Car: 180SX CA18DET
hey guys, first post
first of all Id like to say this forum is awesome, such a great wealth of information! :dblthumb: Ive never even needed to start my own thread until now. Ive searched and tried lots of things but im not 100% sure what to do
Baiscally Im having trouble wiring my safc 2 in. I have z32 maf and 450 injectors. now, it runs, but wont rev past 2000 rpm. so i figure it is a maf issue.
The safc sensor check shows that my maf is not there. its not reading it, and so my car runs super lean.
settings are set for 4 cyl, arrow up. set to pressure and 2 in, 7 out. is that right?
Ive made some pictures in paint. this is the way i have hooked it up. Is my safc airflow signal wiring correct? could it be a broken maf? and, why is there two wires for the airflow meter? (pin 27 and 37) Im using the green and black.
thank you, sorry for bombardment of questions :chuckle:
snags
Car: 180SX CA18DET
no body here can tell me if ive wired it correctly?
float_6969
I haven't had a MAFS for over 5 years, so I'm a bit rusty with them, but I don't think the yellow/green goes to nothing.
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
from driftin8ez-
"I just had to read about 5-6 posts to finally get a definite answer to how to re-wire the CA Harness for one of Nissan's big boy MAF's. This guide will work for the N60, N62, RB20/25 Maf's
CA Harness wire Colors --------> N60, N62, RB20/25 Maf
Green/Black ----------> PIN B
Black -----------------> PIN C + D
Black/White -----------> PIN E
Green/Yellow ----------> No Connection
Leave PINs A+F unconnected if there is even a pin or wire coming from it. Some Maf will only be pins B,C,D,E some will be A,B,C,D,E,F but again leave A+F unconnected.
Enjoy!"
rb20-25-n60-n62-maf-to-ca-wiring-guide-t256699.html
I know for a fact sensor type 07 is the ca18det setting (my safc is 07 in and out)
snags
Car: 180SX CA18DET
okay thanks, so that means my maf is wired correctly. then why is my safc still not finding it?? when i do sensor check, it is not there
snags
Car: 180SX CA18DET
i got the maf wired up right not. and now i have the safc wired right. but it still wont rev past 2 k rpm. any ideas?
Sc0oByDo0RaCeR
Car: 240sx s13- ca18det.
snags wrote:i got the maf wired up right not. and now i have the safc wired right. but it still wont rev past 2 k rpm. any ideas?
are you running a chip ecu?
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
Pink is not afm signal wire on an safc, yellow and white are. one is signal in and the other is signal out, I cant remember which is which though. Also it should be 4 in 7 I believe but maybe your right. Ive had N60 and N62 mafs before and one is 2 in and the other is 4 in but I dont remember 100%
s13drifter88
My$800S14
Car: S14
snags wrote: The safc sensor check shows that my maf is not there. its not reading it, and so my car runs super lean.
bro you should be using Hot Wire 2in 7out thats probably why it dosnt recognize your maf
snags
Car: 180SX CA18DET
reviving dead thread for closure
the problem was because i was using the gtr signal wires orange/pink.
for ca18 it should be yellow/ white.
thx guys
/thread
float_6969
Thanks for reporting back and letting us know what you got figured out.
