RB20/25 N60 N62 MAF to CA Wiring guide....
driftin8ez
Car: 92 Coupe, Turbo Miata
I just had to read about 5-6 posts to finally get a definite answer to how to re-wire the CA Harness for one of Nissan's big boy MAF's. This guide will work for the N60, N62, RB20/25 Maf's
CA Harness wire Colors --------> N60, N62, RB20/25 Maf
Green/Black ----------> PIN BBlack -----------------> PIN C + DBlack/White -----------> PIN EGreen/Yellow ----------> No Connection
Leave PINs A+F unconnected if there is even a pin or wire coming from it. Some Maf will only be pins B,C,D,E some will be A,B,C,D,E,F but again leave A+F unconnected.
Enjoy!
Modified by driftin8ez at 5:13 PM 7/21/2007
float_6969
I suck it in the FAQ, Thanks!
driftin8ez
No... Thank You!
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
float_6969 wrote:I suck it in the FAQ, Thanks!
Where is this FAQ place you refer to, and how much do you charge to suck it?
float_6969
I hate you guys.....
AWDB12wagon
float_6969 wrote:I hate you guys.....
ohhhhh, you dont mean that.
irie_slida808
Car: 420sx
z32 mafs work on ca motor's right?
Buddyworm
Yes, yes they do.
Lobja
Car: Nissan 200sx s13; ca18det
hello buddies :)
i've just got new car S13 with JDM motor, previous owner have changed European motor with JDM, everything in car is STOCK, he changed everything except ECU and MAF, now i have a big problem couse my car won't working properly, i found out that MAF is damaged and i want to buy new MAF. I live in Republic of Georgia and it's a big problem to get good new one. i was looking for STOCK MAF in NET but without result :confused:
Now i have decided to Upgrade my MAF with Z32 or something like this :confused: do i have to change my ECU or Upgrade it ? please i need some advises. help me :sad:
