bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Tue Sep 30, 2008 8:55 am
I should get a vid up when I care again, but again.
It fires over, has fuel pressure, is getting spark, but just wont run. You give it throttle input and it says "maaan, I dont thiiink so" Will not idle good enough to pull more than 10" of vaccuum.
I wish these fuel injectors werent sucha pain to remove, I think thats the next logical step.....view them spraying and make sure none are stuck?
AFR's are rich, Power FC scaled for injectors and AFM however, should (as it has in the past) fire right up and idle beutifully with no AICV and cold start jazz.
and the list of what has been gone through is bonkers, everything you could think of. I have wideband O2, in car fuel pressure, boost/vac, and ECU operating parameters at my fingertips, to check TPS voltage, I go into sensor check under the ETC menue and view it. It makes diagnosing a lot easier, when theres a demon that isnt hiding.
