frapjap wrote:But- I have to ask- as a guy who had a C5 and now has a MazdaSpeed Miata, whats your take?
Two very different types of fun.
The C5 is a snarling, pissed-off, F** YOU car, especially with about $2K in mods. You leave the TCS on not because you're not a skilled driver, but because you can't control the environment, and that car will swap ends with a quickness if you hit oil/wet/gravel/etc. It's actually ALMOST perfect. I say 'almost', because I wish it was a foot or two shorter. It's not a small car, although it acts like one. I'll own another one someday, likely a Z06.
The Miata has nowhere near the power of the C5, of course. Handling is very neutral, in that all four tires seem to break loose at the same time, but not without warning. Its overall dimensions are much more appealing to me (I dislike larger cars). It squirts through traffic without making a scene like the C5, and it flies 'under the radar', allowing you to break the speed limit without drawing as much attention. It's like a playful puppy that pees on the floor when it gets too excited.
Neither car will tolerate crappy pavement well. Both respond beautifully to a good 'track alignment.' Both are totally transformed with about $2K in mods.
Your Miata convinced me to buy the MSM. The choice between the two really comes down to budget. If you want to spend $10K, get the MSM. If you want to spend $20K, get the C5.
