S15 in s13
92vert240
Car: S13 hatch S14SR20 stock record-12.35 at 110, 87 t-type 10.69 at 132. hatch daily.
What would be the total cost to put a s15 drivetrane in an s13 body? Including everything from rear to driveshaft and all that. thanks.
Blown240sx
Car: 1996 240sx
Motor should swpa no problem. The drive train if you have it all might need to be shortend not sure on the tlength of the S15s but if you have the half shafts and drive shaft and pumpkin shouldnt take much more modding. Although sometimes the Pumpkins can have clearance problems.
FattyMcBaggins
Car: 1990 Nissan 240SX
You have to modify the transmission mount some, and get a custom made driveshaft because the S15 shaft mounts up differently than the S13. Also, you need to get a Dakota Digital Speed signal converter. Otherwise the speedo signal is gonna be all whacked out. If you're planning on mounting just the transmission and diff up to an S14 or S13 SR then you will have to use an S13 Flywheel and clutch I believe. I've been considering doing this swap into my S13. It's alot more work and expense than it's worth unless you never want more than about 320-350hp. Otherwise, the 6-speed transmission's tend to give out past that due to thinner gears. If you want to stick with this and want more power, then get the transmission cryotreated ($$$$). For the same money you could just about have a full build on an S13 SR. Just my opinion though. Trust me, I want that 6 speed, but it doesn't seem to be worth it.
92vert240
wow i never knew that about the transmission. I guess i wont be doing that. Its probably hard to finds the 6 speed transmission and diff w/ all the speed sensors and drive shaft and all that. Ide hook it up to an s-14 motor w/ the s-13 clutch and flywheel but it seems that once all is said and done i'll be around 6500-7000. Too much for me. How about s14 in an s13? I want a notch top, all my friends have regular SR black and reds.
new_to_drift
Car: 89 240SX coupe
knotchtop would be about 10X less hassle.Motor mounts are the same i know that,not sure about the driveshaft or transmission.I think they both match up.Wire harness could be sent out to wire specialties if u dont want to deal with that.
FattyMcBaggins
S14 motors go in no problem. if I understand correctly the biggest headache about those swaps is the wiring. And I just realized in my last post I said you have to use the S13 flywheel and clutch...I meant to say S15. MY BAD! Having a 6 speed would be super sweet, but it's just not worth the trouble unless you're only shooting for about 320hp. After that it could become iffy. May be the plan if I get an S14 though...
hazw8st
92vert240 wrote:What would be the total cost to put a s15 drivetrane in an s13 body? Including everything from rear to driveshaft and all that. thanks.
$2500 in JDM parts....
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The S14 and S15 motors are almost identical (as in the block, head, intake, etc.). Its just that the S15 has a different: transmission, differential gear ratio, ecu, wire harness, injectors and speed sensor location.
Badfish
Car: 93 Nissan 240SX w/ black top SR20
J-Spec Tuner wrote:The S14 and S15 motors are almost identical (as in the block, head, intake, etc.). Its just that the S15 has a different: transmission, differential gear ratio, ecu, wire harness, injectors and speed sensor location.
Hey J-spec: Where does everyone get this misformation that the s15 sr20det has a 10:1 compression ratio?
Case in point: zerothread?id=157370
Everything I've found says its 8.5:1 CR It seems this should have been cleared up years ago.
Onizuka
Probably from the S15 (and S14) SR20DE which has a compression ratio of 10:1.
92vert240
so whats up with the harness in the s14 to s13 swap thats such a headach?
new_to_drift
Car: 89 240SX coupe
if the wiring is the only thing your worried about,and you dont feel like sodering a lot.send it to wiring specialties.They wil do it for about 200$.
WVdrift24
Car: 91 nissan 240sx
So really of I didn't use my gauge the sensor wouldn't matter that much correct? Sorry if am lost I just trying to clear things up for me! I am also trying to for a sr but it is more or else going to be a track car
Hijacker
Car: '92 240sx Convertible
'94 F-150
The sensor is only an issue if you're trying to retain your factory speedometer.
zauber
Car: 1991 Nissan 240sx SE coupe powered by s14 sr20det fully built. roughly 500hp
92vert240 wrote:so whats up with the harness in the s14 to s13 swap thats such a headach?
exactly, wiring is much easier than swapping into s14/s15 half of the harness gets tossed in the trash. and to save some headache with the transmission just run an s14 5spd and you won't have to worry about dealing with the VSS being in the diff. and the weaker 6speed gears.
