one ton garage »
https://forums.nicoclub.com/one-ton-garage-u17338.html
Sat Dec 08, 2007 1:10 am
The main question that needs to be asked is: how much pride do you have in your car? And I don't mean to be facetious when I ask that; I'm serious.
Because there are NO aftermarket fiberglass conversion fenders that are perfect. In fact, most of them are quite junk, and the cheaper in price they are, the junkier in quality they are. Funny how the world works that way. But even the "higher end" name brand fenders such as those by Origin are wrought with waves and imperfections on the surface, and the fitment still leaves a bit to be desired.
This isn't to say that you can't use them.. I've seen so so results from these aftermarket fenders, but I'm also very anal about stuff like this, and I've never seen a set that looked "perfect," or even close to perfect. But, again, if you're not a stickler for detail, or if you didn't really care, then those little ripples, or edges that are just a little too short, or the gap between the fender and door that's just a little wider on one side, etc. probably won't matter.
The other problem is that most all those fenders are only available in widened form, and unless you also add overfenders to the rear of the car (which is another can of worms as far as finding quality pieces), you'll end up with something that looks like a tadpole... big and bulbous in front, and all skinny in back.
But if your answer to my og question was, "I have A LOT of pride in my car!" then the BEST way to go would be to modify a set of oem steel fenders to work. Costs more money, takes more time, but ultimate result if done right (and most good body shops should be able to take on a job like that) is a set of fenders that are PERFECT and look OEM, because, technically, they are.
EDIT: Ah, I coulda swore I had these pics of the fender work on my friend's car...just found them! He had originally bought some Origin fenders because they were "the best," but turned out they exhibited all the probs I mentioned above. So it was decided the only way to do it right, was to go oem.I think the end result was worth it though:
Modified by one ton garage at 3:35 AM 12/8/2007
