one ton garage »
https://forums.nicoclub.com/one-ton-garage-u17338.html
Thu Nov 13, 2008 11:38 am
oneeigh: Yup, the rear fenders on the black S13.5 are slightly pulled... The front fenders are steel, made from welding the OEM S15 front section to the OEM S13 rear section. I'm not sure if I posted this pic in this thread or another one, but here it is again:If you notice we spliced them at an angle, which is the only way to preserve the most integral details of each respective fender (the S13's A-pillar point, body line, and curvature where it meets the front half of the door, and the S15's hood edge interface and slightly flared wheel arch). When you do a straight vertical joint like some people do, you don't get that. A little metal work is required afterwards to blend the two together perfectly... to make sure the curves flow into each other... but it's actually quite minor, and the result is pretty major imo. Back to the rear fenders, I wanted to make sure I didn't pull them too much, so I used the angle and size of the S15 front fender's slight bulge as a guide, and only brought the rear out to match that same angle. It's all little detail stuff, but it adds up in the end...
